HELP, Maintenace - Bimmerfest - BMW Forums
Old 06-21-2013, 07:59 AM
Serg335i Serg335i is offline
Mein Auto: 2007 BMW 335i
HELP, Maintenace
Hello All,
I am a new owner of a 2007 335i w/ 45k miles. I have owned the car since Feb. 2013 and just recently took the car to get an oil change to an independent. While completing the oil change the mechanic stated that the Front Control Arm Bushing on the brakes is broken and will need to be replaced. He also stated the brake fluids needed to be replaced.
I am new to BMW and am not the savy with mechanical workings of the car. Other than a slight squeeling in the brakes that I hear when coming to a slow stop, the breaks feel great. The indy wants to charge me $500 to replace and another $130 to change the break fluids.
Am I getting ripped off? How can I tell if the bushing is actually broken and if the fluids need to be changed. Any help would be appreciated!
-Serg335i
Old 06-21-2013, 08:03 AM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
Well, the control arm bushing is not part of your brakes. You need to find out if he's replacing the whole arm or just the bushing. If it's the entire arm, the price doesn't seem to be too bad. Break down the cost of parts and labor.
The brake fluid (in my opinion) needs to be replaced only if you're doing full brake overhaul (pads, rotors, and cleaning the calipers inside replacing rubber parts). Otherwise, not sure why would you need this at 45K.
GL.
Old 06-21-2013, 08:08 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by Serg335i View Post
Hello All,
The charges are market for your work. The good news is: You can save well over 50% on those jobs by doing it yourself, if that's attractive to you.
The control arm involves two [2] nuts. Good price indeed if alignment included. You gotta have it after replacement, so add that cost if not included.
DOT4 brake fluid is available at any auto parts store, NAPA and O'Reilly's coming to mind. Info HERE
Old 06-21-2013, 08:09 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
Brake fluid is supposed to be changed every two years. $130 is steep but not out of the ballpark. If it needs changed you should have the warning on your iDrive or CBS system. If not, it doesn't need changed. The control arm bushing is checked by inspecting it. Your car has very low mileage to need one. It would be cracked or collapsed. You can see the crack in the rubber if it is there. Usually, the entire control arm is replaced. It will have a new bushing and ball joint in it.
Old 06-21-2013, 08:11 AM
///M-Furby's Avatar
///M-Furby ///M-Furby is offline
IntarWeb Stalker
Mein Auto: 2016 M3 SO ZCP
Maybe find another mechanic to get a second opinion? Possibly the dealership just for a looksy?
"Tomato" ED 2016 M3 | B50 | ZCP | X3SW | ZDB | ZEC | ZLP | 2MK | 5DP | 6NS |
"Booberry" ED 2013 335xi | Returned
"Boo" CPO 2006 330xi | Sold
My Drive Style
Because I can.
Originally Posted by cwinter View Post
I agree with furby
Originally Posted by guerilla twang View Post
Hahahaha, I like you furb, you like to live dangerously.
Originally Posted by ProfessorCook View Post
I started to google to find a picture to match furby's suggestion to Gia, but it quickly became clear it was an inappropriate search to conduct at work.
Old 06-21-2013, 08:32 AM
Of course, I assume you guys expect the guy to fully replace brake fluid and bleed the system. He may just take a syringe to it and suck it out of the RES., replace with fresh fluid...
Old 06-21-2013, 08:51 AM
Banned
Mein Auto: 2007-335 HTC
replacing the brake fluid is fairly easy, if you can do stuff like that, and if you have one person in the car to pump the brakes., only thing by doing it your self is I dont think it replaces the fluid in the ABS pump.
Old 06-21-2013, 09:03 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Yup. I find it hard to believe control arm bushings on the E9x chassis are gone by 45k.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 06-21-2013, 09:09 AM
CarlsonTheFlyer's Avatar
CarlsonTheFlyer CarlsonTheFlyer is offline
Paraglide! Walk on air!
Mein Auto: 2010 335i Coupe 6MT
I would agree, unless the car was thrashed repeatedly, or frequently driven off-pavement, or over many many speed bumps at higher speed...
Carlson The Flyer | BMW CCA # 423862
The problem with common sense is that it's not very common.
2010 335i, ZSP, ZPP, M-Sport, Le Mans Blue, 3 pedals of course!
Heated Seats | USB & iPod | Black Dakota Leather
Cobb AP Stage 1 Aggressive + | Cobb FMIC | BMW Performance Exhaust
Previous BMWs:
2001 330i ZSP ZPP 5-speed - sold, but not forgotten.
2007 335i coupe, brakes, bushings, control arms
