Old 06-21-2013, 12:39 PM
ktimov1 ktimov1 is offline
Mein Auto: 2006 328i
Question Service Indicator Symbol ?
When I startup the car, this service symbol comes up stating I will need service in 2000 miles. Any idea what service will be performed? I have about 56,000 miles on my e90.
Old 06-21-2013, 12:47 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
A few....you might want to read stored codes. Not just any reader can display BMW codes. Do you not have iDrive?
Old 06-21-2013, 12:51 PM
No I don't have iDrive. Check control still shows 'OK' probably because the car isn't asking for service yet. I guess I will just have to wait and see. I just figured there was a list of services needed to be performed when this indicator went off.. didn't know it could mean pretty much anything.
Old 06-21-2013, 12:58 PM
Check your manual for instructions: scrolling through codes [that can be displayed].
Old 06-21-2013, 01:27 PM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
Checked the service menu? It gives both dates and times of some maintenance items.
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 06-21-2013, 01:43 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
  1. Sit in the driveway, engine on, car in park.
  2. Scroll the switch on the front of the turn signal until you see "Service info", not "Check Control"
  3. Press the button on the end of the turn signal to bring up the list.
  4. Scroll through the list with the switch on the front of the turn signal.
Old 06-22-2013, 08:38 AM
Tom K.'s Avatar
Tom K. Tom K. is offline
There is a scheduled "Inspection" service every 30,000 miles, so that may be it. It does not require an oil service but includes a number of visual, electrical and mechanical checks and a road test. Your dealer can probably provide a checklist so you can decide if you want to have it done - it should cost about 2 hours of labor. Check out your Warranty/Service manual.
Tom
Old 06-22-2013, 10:08 AM
Zooks527's Avatar
2 hours labor = $200 - $250 at the dealer.
For that money, you can do the list yourself. Find it here: http://www.bimmerfest.com/forums/sho...66&postcount=2
