Old 06-22-2013, 01:58 AM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
E90 wheel alignment
My car had an (angle) wheel alignment by tire shop (for $65) ... it drives better but still not perfect... the steering weight still feels a bit vague
Q1. Is there anything else needs adjustment
Q2. Do I have to take it to BM dealer for it
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 06-22-2013, 04:59 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Alignment is:
  • Front & rear camber
  • Front & rear toe
  • Thrust angle
What're yours? You should have documentation after an alignment.
If wondering, castor isn't adjustable, your ride. If steering/handling not sharp enough, you really should have a look at suspension & differential mods, easily located in this forum and others.
Mileage?
Old 06-22-2013, 08:47 AM
floydarogers's Avatar
Pedant and Curmudgeon
No, but you need someone that will do it correctly. It should be under $150.
Old 06-22-2013, 09:27 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Explain "vague":
  1. Does it wander excessively?
  2. Do you have to continually correct the wheel?
  3. Is the wheel off-center?
  4. Are there any vibrations?
  5. Does the wheel pull when braking?
  6. Did the alignment shop attach weights over the driver's seat area?
  7. Was your tank full and was there weight placed in the trunk?
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 06-22-2013, 04:08 PM
SilverX3's Avatar
Originally Posted by CALWATERBOY View Post
Alignment is:
  • Front & rear toe
  • Thrust angle
Mileage?
38,000km
Watched when they did it ....they adjusted FRONT and rear camber only
Steering a bit vague on rough surface
Maybe tire pressure is too high perhaps
Job - Captain
MY11.5 X1 Xdrive25i
Old 06-22-2013, 04:51 PM
TXFred TXFred is offline
Mein Auto: 2008 335i Convertible
38,000km
Watched when they did it ....they adjusted drink and rear camber only
They adjusted what?
Frederic
Any idiot can be fast in a straight line. The corners are what separates the drivers from the commuters.
Old 06-22-2013, 04:56 PM
SilverX3's Avatar
Originally Posted by TXFred View Post
They adjusted what?
Frederic
sorry front and rear
Job - Captain
MY11.5 X1 Xdrive25i
Old 06-22-2013, 05:15 PM
I'd pay a bit more and have a shop that does a more thorough alignment. If they don't bring you Before and After numbers for your car, you have no way to know if they did the job correctly.
One thing that BMW does is weight the car in order to simulate the suspension compression that happens at speed due to downforce. I found the numbers online previously, and it seemed like it would be easy to pre-weight the car before you bring it in for alignment. Tubs of cat litter are fairly cheap, and are sold by the pound. So they make useful weights.
Frederic
Old 06-22-2013, 05:19 PM
38,000km
Changing camber often changes toe; can change thrust angle. Better get it done right....sounds like toe's out.
Or, you have stock rear subframe bushings and no limited slip differential, sure fire slop over bumps.
Old 06-22-2013, 06:46 PM
SilverX3's Avatar
Ok will book next to have it done Properly
Job - Captain
MY11.5 X1 Xdrive25i
Old 06-23-2013, 10:12 AM
Bemo's Avatar
Bemo Bemo is offline
Mein Auto: 2011 328xi
I dont get these threads, hit your local dealer and for ~$150 you'll have it done right (or at least have a much greater chance of it being done right ).
2015 911 Carrera GTS
2011 328xi
2011 535xi GT
BMW CCA
Old 06-23-2013, 12:44 PM
I wish my dealer charged that little. Double that amount and you'll be in the ballpark.
Frederic
Old 06-23-2013, 04:02 PM
SilverX3's Avatar
Daylight robery
Job - Captain
MY11.5 X1 Xdrive25i
Old 06-28-2013, 04:57 PM
SilverX3's Avatar
Got the wheel alignment done by Bridgestones Tire Centre
The first titre shop (Kmart tire) who did my car they got it all wrong
Damn
Now it drives much better
Here is the report before (Primary) and After (secondary)
I want a refund from KMart
Job - Captain
MY11.5 X1 Xdrive25i
Old 06-28-2013, 08:34 PM
fb88 fb88 is offline
Mein Auto: 2014 X1 xDrive28i
How much did it cost from Bridgestones Tire Centre?
Old 06-28-2013, 08:39 PM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
Oh man ... we were wondering where Kmart went ...... don't let then or Wal-Mart touch your Bimmer .....
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 06-28-2013, 08:44 PM
harooni harooni is offline
2008 335i coupe
Mein Auto: 335i
lmao Kmart.
2008 335i coupe sports package 2008 ML350
Old 06-28-2013, 10:18 PM
SilverX3's Avatar
$70
the machine they used in impressive
like this
Job - Captain
MY11.5 X1 Xdrive25i
