Old 06-22-2013, 07:24 AM
MRjayr MRjayr is offline
Mein Auto: E90 335i M Sport
Pls really need help 06 118i! INPA codes + Transmission!
Hi friends,
Just got the car back from the shop where a cylinder head gasket was changed. Now i plugged my OBD2 cable K+DCAN and scanned for some errors as i got the "Red Car on Lift" icon along with the red park brake light which wont go away even when park brake is down.
Now at this point the car shifts properly and smoothly no transmission problems yet...
Anyway scanned for errors using INPA - Loader E89x v1.07 under "Engine" tab and got the following errors;
2A59 - VVT Leading Sensor or Valvetronic Eccentric Shaft Sensor
Is this something i can replace? Or did the mechanic not put back together my top end properly after the cylinder head gasket replacement?
2E7C - BSD Wire Failure
Would explain the spare wire i found near my battery terminal...
2EBE - BSD from Generator Missing
Have a wire harness under my rear passenger seat that doesnt clip into anything could this be the missing generator?
2EFE - Engine Blower / Electric Fan
Makes sense now that my cooling fan has never came on. It does work though as ive tested it via INPA
2B63 - Camshaft Sensor Outlet or Camshaft Sensor 2 Exhaust
Again, Is this something i can replace? Or did the mechanic not put back together my top end properly after the cylinder head gasket replacement?
2F17 - Forced Switched EGS (Electronic Gearing System) or Engine Oil Temp too High.
If its gearbox related might explain why my car doesnt shift properly anymore. Explain more later...
2B9E - Energy Saving Mode Active
No idea on this one...
2B98 CDKNVRMON - plausibility monitoring of the RAM backup
This one came after i done the Adaptive Value reset on the gearbox i believe..
Error Log .xps File for DME/DDE Screenshot
Over to the Transmission Menu and "Gearbox Control Module GS19" tab.
Now this is where i think i might of f*cked something. I went and cleared all the adaptive values for the Transmission thinking this would give me smoother shifting.
It didnt! I now cant use DS, i can engage it but it wont shift up when i want to. In D it takes ages to shift into 2nd gear, i either have to redline it to shift or slowly buildup speed to approx 30km and then it will shift into 2nd while sitting at approx 3k RPM.
My assumption is that its in some sort of LIMP mode??
So in a desperate attempt to get the old settings i clicked on Read Memory (still under Gearbox Control Unit window)
and clicked all of the bellow one by one;
F1> Read LAR
F2> Read FLASH
F3> Read UIFM
Im not sure what that done
So with the problem still being there i went into the Error Memory (still under Gearbox Control Unit window) and got the following;
Pressed F1> Read Error Memory. No Errors
Pressed F3> Information Memory. 1 Error in Error Memory.
5113 info counter 2 - DME-forced highswitching
(could this mean forced high rpm gear changes?)
Error Log file for Transmission Screenshot
SOOO first things first!
I want my car to shift normal again!!! Please what do i need to do? If i need to provide more info please let me know.
OR if you can comment on any of the errors that would be appreciated too!
Soo many errors!
Thanks to all!
Old 06-22-2013, 06:19 PM
mr_bean mr_bean is offline
Mein Auto: 2000 328i
Take it back to the shop that replaced the head gasket. It seems as though they screwed something up and they should be liable to fix it.
Old 06-22-2013, 07:33 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
I need to buy a scanner too any recommendation..
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 06-23-2013, 01:34 AM
I bought mine off ebay. Works well. Just need to learn how to use the software properly.
http://www.ebay.com/itm/221217479096...84.m1439.l2649
