Old 06-22-2013, 07:59 AM
Averdi's Avatar
Averdi Averdi is offline
Mein Auto: BMW 325i 2006
Weird transmission possible problem?
When I really step on the gas and the car goes to 6 revs...sometimes it slowly goes down to 5 then 4 then 3 then 2 ect. It doesn't just shift down it just slowly revs down. And this is NOT every time. Any have any ideas? I am getting my septic belt changed i don't know of that has anything to do with it? Thanks
2006 325i
Red intake scoops, Red taillights, Red calipers, M3 rep wheels, M bumper, 28% tints, 6000k Angels & Fog lights, clear cornered headlights, Black and White emblems, Smoked side markers
Old 06-22-2013, 08:01 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
If you're at 6 revs you have a major issue. Or did you mean 6000? Ummmm....what do you mean?
I have a septic tank, but don't think I have a septic belt....??
Old 06-22-2013, 08:09 AM
Averdi's Avatar
I'm sorry I'm a noob with all of this. One of the belts. It has to be changed because it smokes and smells like burnt rubber. And yes 6,000 revs.
2006 325i
Old 06-22-2013, 08:10 AM
Averdi's Avatar
And usually if you were to go to 6,000 revs it and you let go of the gas it would shift down to 2,000-3,000 revs but mine goes very slowly from 6,000-5,000-4,000 like that
2006 325i
Old 06-22-2013, 08:47 AM
What's the mileage? Likely belt tension needs adj.
Old 06-22-2013, 08:48 AM
Averdi's Avatar
87k , any suggestions? You always seem to know
2006 325i
Old 06-22-2013, 08:51 AM
Sooo...does it downshift easily? But does not upshift from high RPM?
First things first: check codes. Then, you'll know how to proceed. No, inexpensive code readers and free code readings won't read BMW proprietary codes.
Poss tranny flush time, maybe rebuild kit for sticky valves. Ain't rocket science....tranny pan + filter comes off; vavle body unbolted for work. Reverse w/cleaned or new filter.
Old 06-22-2013, 08:55 AM
Averdi's Avatar
Noo. It up shifts completely fine. No problem with that. it only happens at really high RPMs downshifting. It is a automatic. Like If I go to 6000 RPMs it slowly goes down and it's not every time only sometimes.
2006 325i
Old 06-22-2013, 08:59 AM
Try THIS
If no good, take your valve body out & correct. Don't know what tranny you have - Google for treasure trove o'info.
