Old 06-22-2013, 10:11 AM
Princeton Princeton is offline
Princeton
Mein Auto: 2008 335cxi
Tpms
I will need new tires shortly for my 2008 335xi.
Should I replace the TPMS sensors (or replace the batteries) - or bet that they will last another three years.
Can you replace the batteries - or do you need to buy new sensors?
All opinions welcomed.
2008 335cxi:GRAPHITE METALLIC:JADE GRAY:GRAY POPLAR:PREMIUM:SPORT:HEATED SEATS:NAV:IPOD/USB
Old 06-22-2013, 10:35 AM
E92-Lighting's Avatar
Mein Auto: 335i
we are fully stocked with BERU TPMS sensors, each brand will last in different duration's of time.
http://www.e92-lighting.com/products...tem-950-0.html
BMW ACCESSORIES and PARTS
Old 06-22-2013, 08:05 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
The batteries can't be replaced (although DSX tried). There are various articles on how long the batteries will last, but reliable sources indicate that their life depends on driving mileage and years of service since the TPMS will go into "sleep mode" when not in use. I've seen articles that indicate 5 - 9 years of service...or 5 - 7 years of service depending on "use."
What was the build date of your car...we're now in the middle of 2013...are you a "high mileage" driver? Do you expect your tires to last THREE more years, as your TPMS are now 4.5 years old (depending on car build date).
Certainly, the batteries will "fail" according to a "normal curve," with high mileage, and cold climate users experiencing battery failures at a higher rate.
I'm thinking you'll be at the "edge" of TPMS replacement during the end of your new tire life, depending on annual mileage.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 06-22-2013, 08:56 PM
Princeton
Car now has 71,000 miles. Build date was 3/2008. I am the first (only owner). Expectation is that the replacement tires (another set of Conti DWS) will last the same as the last set - that went 36,000 miles.
Old 06-22-2013, 09:17 PM
pointandgo's Avatar
So if my calculations are correct...and in the "worst case scenario" of 7-year TPMS battery life, they may fail in 2015 near the end of your replacement tire life...if mileage remains the same. Hard to predict if this will be an accurate end of the TPMS battery life.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 06-23-2013, 03:09 AM
DSXMachina's Avatar
Bimmerdex 7.4!
You've brought back some memories P&G. I was able to replace the button batteries on the two types I experimented with but it wasn't cost effective. The battery, as well as the entire circuit board, is encapsulated in a firm gel or resin which is difficult to remove. Although the button batteries were common types the terminals were soldered to the circuit board.
Bottom line: Replacing batteries would cost me more in parts, direct labor, testing and warranty costs than I can buy the new sensors for.
If I were the OP I'd leave the sensors alone and take my chances. An interesting development is that we are starting to see battery failures, but not of all sensors on each car. Odd because they all have exactly the same run times. There are cars on which I changed a sensor a year ago and no others have failed since. All in all though, the battery life seems to be longer than first predicted, just like Prius hybrid batteries.
Old 06-23-2013, 05:19 AM
Princeton
Point & Go, DSX - thank you. I'm gonna take my chances. Based on the additional information you provided, I think that I'll make it through the set I'm buying shortly.
