Old 06-22-2013, 11:55 AM
MovingAverage MovingAverage is offline
Mein Auto: 2004 E46
Fan noise from cold start
This is a 2006 E90 3 series sedan. I noticed from a cold start that there is a loud whirring noise for about 2 minutes, which then stops.
See the youtube video link for the actual recording of the sound
I popped the hood and found out that the fan (radiator fan I think) is causing the noise.
From research, is this due to a faulty theromostat control (is there a part number for this?)
Or is this a failing water pump?
Anything I can do to verify the problem?
Old 06-22-2013, 12:31 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
I believe there is a fuse you can pull and/or a plug for the fan.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
