Old 06-22-2013, 01:54 PM
Mk23's Avatar
Mk23 Mk23 is offline
Corner Carving Addict
Mein Auto: 09 - 335i E92
2 part question regarding reduce power warning
1. How much are solenoid sensors on an n54? (guessing that is the issue but just as well could be HPFP again)
2. Is there a way to check the error code while the warning is showing? I had heard you could do this through check control somehow.
Have a reduced power warning whenever I get on the gas hard, usually after RPMS get over 3-4k. Am out of warranty but have the extended warranty on HPFP and Injectors. Thanks a bunch.
Old 06-22-2013, 03:48 PM
TXFred TXFred is offline
Mein Auto: 2008 335i Convertible
Question 1. I assume you mean the VANOS solenoids. I don't know about the cost, but there's some articles out there about how to clean them. Apparently they fail because they get sticky. Mine were replaced under warranty. But if they act up again, I'll try cleaning them first.
Question 2. I don't know of any way to read codes other than with a cable.
Frederic
Any idiot can be fast in a straight line. The corners are what separates the drivers from the commuters.
Old 06-23-2013, 02:44 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
  1. Use the switch on the face of the turn signal lever until CHECK CONTROL appears
  2. Press the button at the end of the turn signal lever
  3. Use the switch on the face of the button to scroll through messages.
  4. On a particular message, press and hold the button on the end for 2 secs to CCID code.
  5. To exit the system, press the button on the end of the stalk again.
Find the CC code list here: https://wiki.bentleypublishers.com/d...4242A6C62198A5
There's almost no detail on the reduced power warnings using this method, but you may get an inkling of what the issue is if there are other codes. You can also get a free generic code read from the folks at Autozone, or get one of the Bavarian Technic cables (http://www.bavariantechnic.com/buy.aspx, $287 and up) for far more information and utility.
Old 06-23-2013, 06:44 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Well over three thousand posts, you've heard there's some way to check codes.
A jest....
Old 06-23-2013, 04:45 PM
Mk23's Avatar
Frederic
Thank you sir.
THAT'S what I was looking for. Thank you! Will have to try this out next time I get the warning.
A jest....
You know what I mean!
More on topic, I notice that my MPG has taken a nosedive, so I am guessing this is a fuel pump issue? I used to get 20mpg on average and now I am hitting anywhere between 14-16mpg.
Old 06-23-2013, 04:58 PM
Read codes - poss oxygen sensor issue. Maybe not. Data will tell a tale. Nut shell blast lately?
Whattaya say - petition drive? Hidden codes have gone on too long in this country! We've got to drag 'em out into the light of day, kinkin' and spittin'! Shut down the BMW Secret Police - post those codes, with plain English explanations, in iDrive!
Old 06-24-2013, 12:55 AM
Mk23's Avatar
If you are talking about carbon blasting then yeah I've had that done about a year ago. Also use fuel system additive every 3rd or so fill up (not super consistent with that but I try).
Yeah I think BMW or car manufacturers in general are afraid some idiot is going to see what exactly is wrong and try and fix it himself.
