E46 (1999 - 2006)
Old 06-22-2013, 04:47 PM
liquidlightning liquidlightning is offline
Mein Auto: 330xi E46
Unhappy 01 330Xi Won't Start
I was fiddling with the taillights yesterday while my 330xi was running, and then something sparked inside and the car chugged and stopped running. Ever since I cannot get it to start, except for very occasionally it will sputter a bit, maybe 250-300 rpm for about 5 seconds, and then cut out again.
The only code it is showing is P1445 Diagnostic Module Tank Leakage (DM-TL) Pump Control Circuit Signal Low.
Anyone have any ideas?
Old 06-22-2013, 06:56 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
Check fuses. Especially for that circuit.
That fuse may just be one of the ones under the hood.
EDIT: Wait a minute! Might be other fuses back in the trunk too.
Old 06-22-2013, 10:25 PM
Well I checked All of the fuses, both in the glove box, and in the box under the hood. The main 250A fuse in back is also good.
All electronics turn on, and the starter will crank normally, but no engine start.
I tried squirting some starting fluid into the intake, and it started right up for about 5 seconds, then cut out again.
Fuel pump does make a buzzing noise during key position 2.
I tried swapping the fuel pump and horn relays, horn worked with both, but no dice for a start.
Hopefully I'll be able to get to work monday
Old 06-22-2013, 10:37 PM
Time to go thinking about your fuel pump.
Pressure at the Schrader valve at the end of the fuel rail?
Old 06-22-2013, 10:39 PM
I checked the fuel rail, and there is definitely some pressurized fuel there, but I don't know the PSI rating. How can I check it?
Old 06-23-2013, 03:22 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
Might be able to get a test gauge loaner at auto zone or the like. Call your local parts store.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 06-24-2013, 09:25 PM
WOW. It was out of gas. Can't believe this. Looks like my gas level sensor is out.
330xi, e46
