Old 06-23-2013, 02:17 AM
HeroET HeroET is offline
Mein Auto: 325
What problem is this?
Recently I noticed that when I stopped for redlight for a while, my car starts to shake intermittently and randomly. It feels like I ran over a bump. Sometimes it shakes violently, sometimes its gentle.
This symptom started to happen right after I fill a full tank of shell 91 gas.
Does anyone know what problem it is and what should I do?
It's e90 325xi
Old 06-23-2013, 06:51 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
As info for diagnosis, your post is slim pickin's.
Try reading codes - get back to us.
Your engine is misfiring, 'bout as specific as we can be at this point.
Old 06-23-2013, 01:21 PM
wiredread wiredread is offline
Mein Auto: 2006 bmw 530xi
Try burning out the gas in your tank and only use 93 octane on your car that is what bmw recommend.
Old 06-23-2013, 01:55 PM
CarlsonTheFlyer's Avatar
CarlsonTheFlyer CarlsonTheFlyer is offline
Paraglide! Walk on air!
Mein Auto: 2010 335i Coupe 6MT
Actually BMW recommends 91 and higher. And it will actually run OK on 87 or 89 gas. The computer will adjust the timing to compensate for lower octane. You'll have less power and higher fuel consumption, but it will run.
Have your codes read. They will tell the tale. Preferably use the scanner that can read BMW specific codes. The tale will be much more telling. Post the codes here and you'll start to get the idea what's going on.
Carlson The Flyer | BMW CCA # 423862
The problem with common sense is that it's not very common.
2010 335i, ZSP, ZPP, M-Sport, Le Mans Blue, 3 pedals of course!
Heated Seats | USB & iPod | Black Dakota Leather
Cobb AP Stage 1 Aggressive + | Cobb FMIC | BMW Performance Exhaust
Previous BMWs:
2001 330i ZSP ZPP 5-speed - sold, but not forgotten.
Old 06-23-2013, 02:14 PM
TXFred TXFred is offline
Mein Auto: 2008 335i Convertible
Sounds like it's misfiring a bit at idle. Like the others say, it may be the gas.
If you want to look under the hood, I'd check out the air filter. If it's badly clogged, it might cause this sort of behavior.
But I'm just guessing.
Frederic
Any idiot can be fast in a straight line. The corners are what separates the drivers from the commuters.
Old 06-23-2013, 02:59 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
or Vanos solenoid
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 06-23-2013, 03:01 PM
Mein Auto: 325
Thanks for the advise. But in Bay area there seems no 93. The premium is 91.
The only difference is I fueled at a station that I never been to before.
Old 06-23-2013, 03:03 PM
Mein Auto: 325
Can you please recommend a good BMW code reader?
Old 06-23-2013, 03:31 PM
riviera1969 riviera1969 is offline
VELOZV
Mein Auto: 2008 BMW 335I STICK SHIFT
I'm in Saccratomato
If ever come by I'm south of Sac in Galt i will check it for you it could be different things
e-mail me at riviera69@sbcglobal.net
Old 06-23-2013, 03:51 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
The fuel may have been bad, but it sounds more like a coil.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 06-23-2013, 04:11 PM
Bemo's Avatar
Bemo Bemo is offline
Mein Auto: 2011 328xi
I had a similar problem, rough idle on cold start. My SA had a similar problem on his leased 328xi and the vanos solenoid replacement did nothing. I got a higher software version and it made the problem go away. He followed with the same and reported good results.
As others have said, we are just guessing at this point. Have the codes read or bring it in to the dealer or a knowledgeable, and well equipped, indy.
2015 911 Carrera GTS
2011 328xi
2011 535xi GT
BMW CCA
Old 06-24-2013, 07:18 AM
Bavarian Technic tool, also known as the BT Tool. They are quite pricey though. Check on eBay.
My car is Cobb tuned, so I use my Cobb Access Port to read BMW and generic codes.
Previous BMWs:
Old 07-08-2013, 06:22 PM
Mein Auto: 325
update:
3 days ago, when I got off freeway, the car started to shake like run over a bumpy road, engine light went on, after I stop/start engine, problem gone and engine light went off.
I brought the car to a local shop for diagnose, the error code is 29CD, misfire on cylinder 1. The man swapped coil 1 and 2, ran a few miles, the problem didn't occur anymore but he was expecting another error on cylinder 2 so that it's a bad coil.
Will this 'swap' resolve the issue? Or there maybe more potential issues?
Old 07-08-2013, 06:44 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Re: What problem is this?
Should happen again. Are those original coils?
Sent from my SCH-I405 using BimmerApp mobile app
Old 07-08-2013, 07:09 PM
thekurgan's Avatar
Bad Lieutenant
update:
Sounds like it may be intermittent. Whenever I have one bad coil, I usually buy two, chances are another may go bad and you'll have something to replace with right away. Coils can be had cheaper online regardless.
Ilse
Bruna
BMWCCA #453648
Old 07-08-2013, 07:35 PM
Mein Auto: 325
Yes original ones.
Old 07-08-2013, 07:49 PM
sptt144's Avatar
Take it to the dealer. There is a tsb and you can get them replaced under warranty due to old coils being faulty. Got new injectors and coils at 35k.
Old 07-09-2013, 07:20 AM
cwinter's Avatar
cwinter cwinter is offline
Here comes trouble!
Mein Auto: 2009 328i E90 :)
Good advice, but I'd almost just go ahead and replace all at that point. Once one goes they generally all go pretty quickly. If you plan to keep the car, might as well get it done while you are not stranded somewhere.
2009 328i Sedan - Ordered: 2/24/09 .:. Delivered: 5/6/09
Jet Black | Black Dakota | Aluminum | Premium | Sport | Xenon | CA | Split Fold Seats
You will rue this day, RUE THIS DAY
Old 07-09-2013, 09:23 AM
Mein Auto: '06 AW 330xi
Originally Posted by SilverX3 View Post
or Vanos solenoid
Yea my money is on the vanos solenoids.
They are easy to access and remove. They are right in the front of the engine when you look into the engine bay. You have to remove the engine cover to get better access but you can see then without remove it.
They're held in by 8mm screws I believe. Remove the intake and exhaust solenoids and blow compressed air through them. Some people use gasoline or brake cleaner, but I've only used air.
If they keep sticking or are mechanically jambed (DME will tell you so if you have a BMW specific fault scanner), they will need to be replaced.
Old 07-09-2013, 09:26 AM
Well I think it's obvious I didn't read the whole thread before I posted that last one....
Old 07-09-2013, 10:10 AM
thekurgan's Avatar
Bad Lieutenant
OP has zero symptoms related to the solenoids, his issues are at idle and coming to idle.
Ilse
Bruna
BMWCCA #453648
Old 07-09-2013, 10:21 AM
When my solenoids were sticking, they caused sporadic idle but that's besides the point. It looks like he got his issues sorted out.
Old 07-09-2013, 10:23 AM
sptt144's Avatar
Use 87 after this tank full if you.don't find a change our pinpoint the problem. If out goes away, its your vanos getting stuck.
Old 07-09-2013, 10:35 AM
Ultimate_drivin Ultimate_drivin is offline
Mein Auto: Bmw 645
Do not use 87 gas that should never be in ur mind use bottle of injecter cleaner Any brand u want and fill up ur tank u should be good to go I did this to my cousins bmw and problem gone ur injectors are clogged
Old 07-09-2013, 12:36 PM
sptt144's Avatar
I meant 89! Sorry (does anyone even have 87 gas anywhere anymore?). I read that if it solves the issue, it is a timing problem with the solenoids. So sorry!
