Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X3 F25 (2011 - current)
The latest X3 brings added style and new features to the BMW's mid-sized SUV. Talk about the BMW F25 X3 with other X3 owners now!
Old 06-23-2013, 12:31 PM
alex md alex md is offline
Mein Auto: 2014 X5 50 M sport
Poorly functioning AC in 2013 X3
Hey Everyone-
Just looking for advice although I am pretty annoyed with this issue in my 2013 X3 3.5 MSport.
I have been a BMW customer for 15+ years and had multiple cars (as witnesses by my signature). I never had this issue in any car. The AC is not functioning properly. I have been to the dealership twice. The first time they kept the car for a day and concluded that everything is OK. The second time they kept it for two days and acknowledged a lower level of coolant than usual. According to SA, they refilled coolant level. The last couple days, I have been driving my car in 85 degree weather and keeping the AC at 68 and high fan and still not comfortable in the car. Obviously, I did all crude and minor adjustments with red, blue as well as recirculating and it has gone nowhere. On Monday, I am planning to go back to the dealership and discuss this issue with Service Department Manager as well as BMW NA. This car barely has 3,000 miles and we didnt know about this issue until the real heat wave began.
Thanks for any advice/guidance to be provided.
Alex
P.S. No evidence of coolant leakage because as per SA, they put dye in the coolant.
2014 X5 50 Msport
2013 X3 3.5 ZMP,ZCW,ZPP,Carbon black/black/wife/ 2011-2014 550xi M sport/ED/
2007-2011 X5.4.8/E70/
2010-2012 GLK 350/wife/
2008-2011-328XI
2004-2007-CLK55
2007-2010-X3 3.0
2001-2004-A8 4.2
2004-2007 X5 3.0/E53/
1999-2001-SL500
1996-1999-ML320 4MATIC
1992-1995-VOLVO 850 TURBO
1990-1992-525I
1987-1990-OLDSMOBILE CS
1981-1987-LADA/VAZ 2103
Old 06-23-2013, 12:37 PM
Teemo Panda's Avatar
Teemo Panda Teemo Panda is offline
Bimmefest Plasti-Dip Guru
Mein Auto: E53, E46-M3, E70, F25-X3
Turn the dial down to 60 degrees, and make sure all vent position button on the left are illuminating green.
If this doesn't help, try comparing it with one of the dealers X3 on the lot ~
Old 06-23-2013, 01:00 PM
Just did, 60 and ALL buttons green no difference whatsoever. Thanks Alex
2014 X5 50 Msport
2008-2011-328XI
2004-2007-CLK55
2007-2010-X3 3.0
2001-2004-A8 4.2
1999-2001-SL500
1990-1992-525I
Old 06-23-2013, 03:46 PM
Drewsky's Avatar
Drewsky Drewsky is offline
Mein Auto: '14 X3 35i-M Space Grey
Originally Posted by alex md View Post
Hey Everyone-
Alex
It could be the heater control valve. BMW's are well known to get sticky HCV's after awhile. You can test function yourself. It is easiest to to this if you have a digital thermometer and a mild-to-cool ambient temperature (but above 60).
Set temperature to 60 deg. Fan high. Recirculate to manual (fresh air). AC OFF. Engine should be at normal operating temp. Temp blasting from vents should closely match that of outside air. If it is significantly warmer then your HCV may be leaking engine coolant into the heater core. My old 2002 e46 did this about every 18 months.
