2 questions about my 2011 335is coupe - Bimmerfest - BMW Forums
Old 06-23-2013, 11:39 AM
Yano729 Yano729 is offline
Mein Auto: 2011 BMW 335is
Here are some questions I have. In the first picture, I noticed something behind the middle rear view mirror, I thought that this may be automatic brightness control but can't seem to find the button anywhere near the steering console? anyone have any suggestions on what this might be?
And my second questions is, I have been reading about the launch control feature and have been wanting to try it out for sometime. I know that you need to disable the DTC but when I do, I get this warning sign on my dashboard. Do i need to take my car back to the dealership or is that normal for that warning to appear? Anyone have any comments on that?
Old 06-23-2013, 12:57 PM
TXFred TXFred is offline
Mein Auto: 2008 335i Convertible
http://www.bmwusa.com/Standard/Conte...modelcode=1183
Any idiot can be fast in a straight line. The corners are what separates the drivers from the commuters.
Old 06-23-2013, 01:03 PM
floydarogers's Avatar
Pedant and Curmudgeon
As Fred says, RTFM.
Rain sensor.
You don't have launch control - only M3 and 335is do.
Smaller pics next time.
Old 06-23-2013, 01:36 PM
Im sorry about the pic, I tried to resize them, but I guess it didn't work. I have a 335is
Old 06-23-2013, 02:58 PM
Sorry, saw a 328 somewhere - might have been the previous thread...
Old 06-24-2013, 05:24 AM
bump? anyone have a solution as to why I get a warning sign with the DTC?
Old 06-24-2013, 06:00 AM
BuraQ's Avatar
BuraQ BuraQ is offline
Moding is Addictive
Mein Auto: DCT 335is BQ Tuned
Your suppose to see that light. Launch control ready is:
Sport Button
DTC On (One Press of the TC button)
Gear in M1 (Push the shift to the left, then press up for M1 mode)
Most important, you need to have over 1300 miles on the car for LC to work
Old 06-24-2013, 07:04 AM
Ok so let me ask this just to clarify. When I push the dtc button and get that warning sign, this means that the dtc is on or off? Why would I get a warning sign if it was on, isn't it suppose to provide better traction when I am driving? What am I suppose to do when I want to drive with the dtc on and not perform a launch control.
Old 06-24-2013, 07:33 AM
BuraQ's Avatar
Moding is Addictive
The light is to let your know that DTC half off for "Sport Traction" when the Sport button is enabled. When not using LC, no lights, DCS is "fully on"
If you press and hold down the DTC button for 10 seconds it will 100% completely disable DTC and you will see you get a different light for this
daytrader daytrader is offline
Mein Auto: 2010 E92 335i
Seriously, you really should read the owner's manual, lots of important info.
As you push the traction control button once it disables the traction control over wheel spin, thus the DTC lights up on the dashboard. Hitting it twice turns off even more control, at least that is how it is on my 2010 I coupe, not sure re your IS. Again, read the manual for full clarification in reference to your specific auto.
Old 06-24-2013, 07:35 AM
Look, it's clear at this time that you have ignored our urgings to read the manual. If you had done so, 1) you would know the purpose of DTC, and known that 2) it changes the operation of DSC. You would also probably know the purpose of other indicator and warning lights - there are around 100 different things that can show up (mostly related to maintenance.)
The light is ON because you have TURNED on DTC, not turned it off.
BTW, the description of DTC/DSC and other things is on page 82/83 of my manual. Look it up in the index to find it in your manual.
Old 06-24-2013, 11:38 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 06-24-2013, 11:44 AM
harooni harooni is offline
2008 335i coupe
Mein Auto: 335i
i get that warning signin my 335i because the seat belt is not in. see the big seatbelted man on screen. try that.
2008 335i coupe sports package 2008 ML350
