1999 323i Auto trans dipstick, how to tell how much to add??..gm trans. - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 06-23-2013, 05:35 PM
ericwest ericwest is offline
Mein Auto: bmw 1999 323i
this car is fairly new to me...and the trans started slipping...I think its low on fluid...I know some bimmers have noway to add fluid..but I have a round cap that says trans oil only in the engine compartment and I this car has the gm trans...the dipstick has several lines on it..but none say full or low or add a quart...so how do I read this dipstick??
Old 06-23-2013, 05:49 PM
computerwhiz1 computerwhiz1 is offline
Mein Auto: 2000 323i
That compartment in the engine bay is the power steering reservoir. The power steering systems in these cars take automatic transmission fluid. The transmission its self is "sealed" with a "lifetime" fluid. There is no dipstick. The procedure for topping off the transmission involves getting the transmission up to a certain temperature and topping it off until it runs out the fill hole. The procedure isn't all that hard, but I can't recite it from memory. My transmission leaks and when it gets low it will start to slip so there is a good chance that is what is happening with you. I would either take it to a shop, or read up online about the topping off procedure. If the fluid has been in there a while it wouldn't be a bad idea to go ahead and change the fluid all together.
Old 06-23-2013, 10:31 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
You need some remedial learning. Read the wiki carefully
Old 06-24-2013, 06:29 AM
what a drag ...you have to get under the car to add trans fluid!...this is the second big disappointment...the first is a cooling system that everyone seems to agree is unreliable...especially the expansion tank
Old 06-24-2013, 07:49 AM
Augster Augster is offline
Mein Auto: M1A1 Abrams
To gain access to the transmission check/fill plug, you have to raise the car at least a foot or more equally all around because the transmission must be level in order to properly check the level. I couldn't raise the rear of the car with my floor jack because there is insufficient clearance to operate the pump arm, so I ended up jacking on one rear jack pad to get a jack stand precariously on a sturdy suspension mount in order to get the floor jack under the center differential support cross member to raise and support the rear properly. Raising the front is equally problematic, but since I have Race Ramps, I was able to lift the front on the lower A-arms until I could slide a ramp under each wheel (FYI my car was deadlined so I couldn't drive it up the ramps). Even then, with typical 18" max-lift hydraulic jacks, I couldn't use a creeper to get to the transmission plug as it's just not high enough. Otherwise, checking and filling the transmission wasn't too bad; just tedious. You must use some sort of fluid transfer pump to get ATF in: Because I had to pump in 9+ quarts, I bought a pressurized Power Fill Pro which made it quick and easy to top off the ATF.
2008 335i Sport Sedan AT
Old 06-24-2013, 07:58 AM
...And yes, I agree the cooling system design and quality is absolutely awful; too much reliance on plastic and the interface methods of joining some components is plain short-sighted thinking.
Old 06-24-2013, 03:03 PM
BMW318i_E36 BMW318i_E36 is offline
Mein Auto: 2011 BMW 328i, 11 X5 35d
Lifetime = until your power train ends !!!!
This is just a marketing gimmick, if its lifetime and if the fluid gets low, will it rebuilt or replace your transmission, free of charge ? I think not !
I have 219,xxxkm with original automatic fluid. I contemplating changing mine. Why couldn't they stick with the Dextron fluid like they did in the past ?
Change it every 50,000km, and have a damn fill and top up from the engine bay.
