Old 06-23-2013, 06:38 PM
longerone longerone is offline
Mein Auto: 328xi coupe
Lights out problem.
I bough a used 07 BMW 328xi coupe with 290k on the odo. Very clean and functions perfectly. Some weeks ago it started to exhibit a problem resembles a battery terminal loosing contact. The last time it does this the whole power went off, as i slide the drivers seat to asses the back seat, the power suddenly comes back on. As at now the power is off again and the car is locked. I couldn't open the cabin or boot to asses the battery and check for possible corrosion at the battery terminals. Bought the car with key fob only, so no power no asses to boot.
How can i get the boot open to check the battery. Do you think its the battery terminal or some other problem?
Old 06-24-2013, 05:31 AM
richidoo richidoo is offline
Mein Auto: 2008 E90
There is a current recall for this, #94229. The battery cable comes loose at the fusebox, not at the battery.
http://www.motortrend.com/cars/2008/...eries/recalls/
Old 06-24-2013, 07:31 AM
CarlsonTheFlyer's Avatar
CarlsonTheFlyer CarlsonTheFlyer is offline
Paraglide! Walk on air!
Mein Auto: 2010 335i Coupe 6MT
Doesn't you key FOB have a physical key inserted into it?
Name:	2013-06-24 10.27.28.jpg
Carlson The Flyer | BMW CCA # 423862
The problem with common sense is that it's not very common.
2010 335i, ZSP, ZPP, M-Sport, Le Mans Blue, 3 pedals of course!
Heated Seats | USB & iPod | Black Dakota Leather
Cobb AP Stage 1 Aggressive + | Cobb FMIC | BMW Performance Exhaust
Previous BMWs:
2001 330i ZSP ZPP 5-speed - sold, but not forgotten.
Old 06-24-2013, 06:48 PM
Heyyy, i never checked.Dumb me, thanks carlson.
Old 06-24-2013, 07:00 PM
ericgt79 ericgt79 is offline
Mein Auto: 08 335i
Lights out problem.
If its the battery cable BMW says there's a recall on that. Keep trying to get my car in there but life keeps happening.
Old 06-24-2013, 07:19 PM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
Originally Posted by ericgt79 View Post
If its the battery cable BMW says there's a recall on that.....
Yes, it sounds like the battery cable could produce the symptoms described by the OP. Cars in the US are covered by the recall. I am not sure the recall covers cars based in Nigeria.
Alpinwei▀
E46, E83, E90 (all with three pedals)
F25
BMW CCA member
Old 06-25-2013, 03:02 PM
No cover here, so i have to buy this cable and fix it myself. I hope its not a difficult task. I understand the battery cable came loose at the fuse box. If this is the case, i assume the solution is to find the loose end at the fuse box and re tighten it.
