E46 (1999 - 2006)
Old 06-24-2013, 08:41 AM
ericwest ericwest is offline
Mein Auto: bmw 1999 323i
99 323I with gm trans. did a weird thing. stopped working for 10 minutes...why???...
I was driving and everything was fine...this car is a 99 323i with gm auto trans...came to a stop sign and then the car didnt want to go again...car accelerated very SLOW...barely going forward....I pulled over...tried to get back on the road...but the same thing...so pulled over and turned it off...called AAA...then about 15 minutes later while waiting I started it again and tried it again and it ran perfect!..put 50 miles on it with out a problem.... any ideas what might have caused this????....I just found out that you have to get under the car to check and add trans fluid and I have not done this yet... would low or burned or lousy fluid cause an intermittent issue like this? or would it be a trans fault? maybe the trans control box behind the glove box??..your help would BE GREATLY appreciated!!...
Old 06-28-2013, 08:28 PM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
When you pulled over and shut it off, you reset the transmission. It was in failsafe mode when you left the stop sign, which is third gear. Get it scanned and post up the codes.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
