central locking - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 06-24-2013, 08:38 AM
Jimmy1982 Jimmy1982 is offline
Mein Auto: Bmw 323ci
central locking
Hi! When I press unlock button on my key all I get is a sound but pins wont go up!
Anyone any idea? Thanks!
Old 06-25-2013, 05:58 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
Dead or dying battery? Can you open the door with the key in the lock? Then see if your battery has enough juice to start the car.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 06-25-2013, 08:02 AM
thanks for reply battery is fine I can open door with key manually but only my side for passenger I have to do it from inside
can lock it with button both sides no propblem
Old 06-26-2013, 06:54 AM
ahull's Avatar
Look in the e46 wiki about re-synchronizing your key to the car. It could be that. Link above your first post above.
Old 06-26-2013, 07:58 AM
Just tried both keys work but pins still wont go up! Do you think that it might be actuators?
Old 06-26-2013, 03:21 PM
ahull's Avatar
The button inside the car will send the pins up and down, right? That would rule out actuators I'd think. Did you try the resynchronize procedure in the wiki?
Old 06-26-2013, 04:01 PM
I did synchronized the key! the inside button make only noise wont lock or unlock, key will only lock both doors pins go down but wont unlock, manually I can only unlock my side not passenger, also I can open boot and petrol flap with key Got the relays replaced and the only plus is that i get at least unlocking sound.
It really bugs me!
Old 06-27-2013, 12:47 PM
Fishful Thinking Fishful Thinking is offline
Mein Auto: '04 325ci
When you say you got the relays replaced, are you talking about those in the GM5?
Old 06-27-2013, 12:53 PM
Old 06-27-2013, 03:30 PM
yes that's them
Old 06-27-2013, 04:09 PM
scottjoh scottjoh is online now
Mein Auto: 1999 323i
central locking
If the relays where replaced and the board wasn't damaged in the process then most likely the problem is the door lock actuators. If the problem was intermittent unlocking problems then that is most likely a module problem. If the unlocking problem is not intermittent (solid failure) then it's most likely the actuator(s).
If the key remote works the trunk and locks the doors then do not attempt key resync. It's not needed. The key is already synced. I test keys I repair on my car all the time and one day right after syncing a couple keys for testing the whole module (GM5) died. All functions, windows, wipers, door locks, interior lights, keyless entry, alarm and trunk release all dead. People call me the GM5 guy and I was not able to repair it. I had to install a new one and get it coded to my car. The odds are that nothing bad will happen, but, if it's not needed, don't do it.
Old 06-27-2013, 04:55 PM
Hi! Since I changed those relays i'm getting unlocking sound its like the car is unlocked coz I can open boot and petrol flap just those stupid pins won't go up!
Old 06-27-2013, 06:53 PM
Like I said in my previous post, "If the unlocking problem is not intermittent (solid failure) then it's most likely the actuator(s)." Actuator failure is much more common on the coupe and convertibles than on the sedan or touring (wagon).
Old 06-28-2013, 08:24 AM
Ok thanks Im gonna get some but before I do is there any way to test them first?
