Bluish smoke - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 06-24-2013, 10:18 AM
Strim Strim is offline
Mein Auto: 320Ci E46 Convertible
Bluish smoke
I have read numerous posts regarding blue smoke out of the exhaust. My problem doesn't seem to be covered from what I have read. Here is my problem. I have a 2001 E46 320Ci Convertible. It has approximately 103,400 miles on the clock. When the car is coasting down hill, and I have to keep applying the brakes to keep my distance from the vehicle in front, when I accelerate at the bottom of the hill I get quite large clouds of smoke out of the exhaust. Now, if I were to go down the same hill and not apply my brakes, then usually there is no smoke! There is no smoke on acceleration on flat or uphill roads, nor after waiting at lights or in traffic when accelerating away. Nothing noted at start up in the morning either. I have changed my VANOS seals, and had the CCV Valve replaced. There is no loss of coolant. I would say that the blue smoke has actually got worse after having the CCV Valve replaced. As I said, this problem only seems to appear when coasting downhill applying brakes. Has got me baffled. Any ideas or help would be greatly appreciated.
Old 06-24-2013, 10:24 AM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & ST 335i
You either have tons of oil leaking into a cylinder or the CCV was installed incorrectly. Leaking oil into a cylinder can be bad valve cover gasket or bad grommet on one of the screws. ( I know because it's happened to me ).
"Be yourself for who you are, or be no one at all" - MalibuMafiaV
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
Old 06-24-2013, 10:38 AM
Thanks for that very quick reply MalibuMafiaV. I did replace the valve cover gasket and all the grommets whilst replacing the VANOS seals. I take it the only way to check that is to remove everything and have a good look!
Old 06-24-2013, 10:46 AM
TheMalibuMafia
Yeah I can almost guarantee you missed a grommet on a screw or it's not sitting properly against the valve cover. I would just remove the cover on top and take a look to see if you see any oil dripping anywhere from the outside first without taking the entire valve cover off.
TheMalibuMafia.com
Old 06-24-2013, 11:08 AM
I was pretty damn sure I replaced all the grommets. I will take a close look at the outside and go from there. I hope it's not the CCV Valve, although I have had to take the car back to the garage more than once for them to rectify their mistakes! Will post when I know more. Thanks for your info.
Old 06-24-2013, 11:10 AM
TheMalibuMafia
Np. Let us know how it goes.
TheMalibuMafia.com
Old 06-28-2013, 01:29 PM
An update. Checked for oil leaks on the outside. None present. Started to remove the coils, and noticed a bit of oil on #4 coil. I thought the gasket wasn't seated properly, so off came the cover. I bought a new gasket set from the local BMW dealer, and when I checked the new inner gasket with the one I had just removed. The depth of the two differed in that the new set was deeper, so I thought perhaps the set I had removed hadn't sealed properly and hence the oil. I replaced the gaskets and set off for a drive. Same problem! I have been to a couple of garages to discuss the problem, and they think it's either a piston seal problem, or valve seals, Either way it's getting expensive. I have booked the car in next Friday for a pressure check of the pistons etc.
Old 06-28-2013, 01:48 PM
TheMalibuMafia
Hummm. How many miles are on the car?. Has it overheated ever? is it manual or auto?.
TheMalibuMafia.com
Old 06-28-2013, 05:04 PM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
I've read recently that getting smoke on/after decel is either valve stem seals or piston rings..... thinking it's the stem seals. Search on that. Do you also get a puff on cold start?
Failing CCV also introduces oil into the combustion chamber so it could also be that.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 06-29-2013, 03:16 AM
Car is an automatic, and done about 105K miles. Never overheated, as far as I know. Had the CCV Valve replaced about 2 months ago because of the smoke. It seems worse now, but having spoken to the garage guys, this is probably due to the extra vacuum suction that the new CCV Valve has created. There was a split on one of the hoses that was replaced which didn't help matters much either. There is no smoke on start up, which tends to lead me to valve stem seals rather than a piston ring problem. Hopefully will become clearer after the pistons have been pressure checked.
Old 07-08-2013, 05:37 PM
Had the engine pressure checked. Was around 200 (psi I presume). The garage put some solvent/cleaning fluid in the engine oil, ran the engine for around 20 minutes or so, changed the engine oil then carried out a pressure check again. The pressure was raised to around 225 (psi). Obviously had cleaned some deposits and crud from the engine. Have been out in the car again, hoping that this may have cured the problem.....No change really, though it may not be quite so smoky. Looks like I'm going to need to have the valve stem seals replaced. I don't think the piston seals are faulty as the pressure seemed good, and there is no smoke on start-up. Time to get some quotes.
Old 07-10-2013, 10:41 AM
forzadesign forzadesign is offline
Mein Auto: 2002 e46 sedan S/P
blue smoke after coasting downhill
I have the same problem. i live on a mountain and when i get to the bottom then take off from the stop, puff of blue smoke. Car runs perfect. Burns a good amount of oil. 344K miles new CCV, VCG, etc.
Comments?
Thanks,
