Old 06-24-2013, 02:12 PM
8355adam 8355adam is offline
Mein Auto: 2006 330I ZSP
What would a smart guy do here?
Tstat is throwing codes and i'm pretty sure its failed open.... I have been driving around on it for approx 1,000miles. Im expecting to take a long trip in a couple weeks and also i dont want any long term emissions issues from the bad tstat. Indy wanted $1500 to replace tstat and water pump. I would rather save $1000 and DIY even though i have never done i before but i have access to tools and mini lift. Car has 90k miles now so im expecting the waterpump to blow anytime between now and another 30k miles. I find it hard to justify pre-emptivley changing out a $550 part when i dont have bags of cash around but at the same time dont want to have to repeat much of the same stuff to replace the pump a few thousand miles after the thermostat. What would a smart guy do?
2006 E90 330i 6MT sport, premium, cold weather, style 162 (winter) 135 (summer)
Old 06-24-2013, 02:22 PM
harooni harooni is offline
2008 335i coupe
Mein Auto: 335i
how long do you plan on keeping this car?
2008 335i coupe sports package 2008 ML350
Old 06-24-2013, 02:37 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
i would change out both while i was in there-- mostly because with my luck i would get about two days before the pump died after the thermostat. then comes all the same work and another coolant bleed....
since its not a q of if but when... i would just suck it up and replace it now.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 06-24-2013, 02:38 PM
hopefully to 150k no reason why it shouldnt make it to that without serious issues.
Old 06-24-2013, 02:48 PM
Kamdog's Avatar
Kamdog Kamdog is offline
<- Bailey
Mein Auto: 2008 535i
I look at these kind of things in a different way.
My rear shoes, with 62K miles on them.
I had the car in at the indy, and the rear shoes had not yet been changed, and he calls me up (I told him to take a close look at them, the iDrive said I still had a few thousand miles on them), and tells me, yeah, you can probably get another 3, 4, 5 thousand out of the pads. How is the rotor? Still good. OK, says me, change out the pads. I got 60K out of these pads, if I get another 50K out of the new ones, that would be great and not at all unexpected. If I blow it and hurt the rotors, I will be in for a bigger bill.
So, if you got 90K out of the combo, and change them out before there is a problem ( you know you need the tstat, you also know the pump is on a count down), you get another ~ 90K miles without a problem there.
Or, maybe, you are on the side of the road in Winslow Arizona, or where ever you are going, with a blown water pump, and maybe something worse.
535i, Monaco, Cream, Light Poplar, Comfort Seats, PP, Nav, ED.
Old 06-24-2013, 03:25 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Bite bullet.
Do both, or will turn into two PITA jobs, the latter an a much less convenient time.
Sorry! Have DIY for N54 only. Anyone?
Old 06-24-2013, 03:51 PM
2008 335i coupe
Mein Auto: 335i
if i was planning on keeping it another 50-60k miles then yes id do both at the same time asap. but if i was planning on selling it in 10kor so . id roll the dice and maybe get indy or diy just for the tstat.
Old 06-24-2013, 04:33 PM
tturedraider's Avatar
Freedom isn't free!!
You'll probably be fine driving a few thousand miles with it failed open. It took me that long to realize it had happened on my E46 330i. Temperature wise you won't really notice until summer ends. You may see your mpg's drop off.
www.bmwcca.org
Old 06-24-2013, 04:44 PM
GeoX750Li's Avatar
GeoX750Li GeoX750Li is offline
Mein Auto: 2010 750Li X-Drive
You might want to shop another Indy. That $1500 sounds a lot for 2 very basic repairs.
Old 06-24-2013, 05:24 PM
3two8iguy's Avatar
3two8iguy 3two8iguy is offline
Mein Auto: 2011 E90 328i sedan
Cant help but ask why folks don't protect the investment you've made by investing in the BMW Extended Warranty/Maintenance.
Life is a Journey,Enjoy your ride.
Old 06-24-2013, 05:55 PM
Kamdog's Avatar
<- Bailey
I can't speak for others, but doing the math, my indy is cheaper than BMWs maintenance, and I can self insure for future failures. Having bought the car new, I know I did the extra oil changes, never skimped on any service or materials, and garaged the car. I know how I drove it, so I am self insuring.
Old 06-24-2013, 07:19 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Originally Posted by Kamdog View Post
[snip]
Did someone mention Winslow, Arizona?
OP, the pump isn't going to last another 90K. Do it now, or do it later at possibly greater inconvenience and expense.
Old 06-24-2013, 08:23 PM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
(oO (||||) (||||) Oo)
Mein Auto: 2009 328i E93 MT
Wow, how time flies. Thank you DSX, for rolling back the years!
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|BMW Performance Exhaust|CDV Delete|Shark Fin Antenna Delete|Front Reflector Delete|LUX H8 Angel Eyes|328i|3 Pedals|Das Fahren im Freien
Old 06-24-2013, 08:30 PM
Pilgrim's Avatar
Pilgrim Pilgrim is offline
Car guy since 1968
Mein Auto: 2008 E91 328xi Sportwagon
My approach is never to fix a car half-assed. You might do the thermostat and have the water pump go out the next day. Do it right the first time.
1983 Datsun 280ZX Turbo
2000 Jeep Grand Cherokee
2008 BMW E91 328xi Sportswagon
2009 BMW E92 328ix Coupe
Old 06-24-2013, 08:32 PM
When I was stationed at the Presidio of Monterey in California I specifically stopped on the drive out there to spend the night in Winslow, Arizona.
www.bmwcca.org
Old 06-25-2013, 05:32 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Any girl, my Lord, in a flatbed Ford, stop and take a look at you?
[DLIFLC? Or before?]
Old 06-25-2013, 05:44 AM
Kamdog's Avatar
<- Bailey
Thanks for the memories.
Old 06-25-2013, 06:30 AM
3ismagic#'s Avatar
3ismagic# 3ismagic# is offline
HerrDoktorProfessor
Mein Auto: '11 335d
There are two parts to your question 1) do T-stat and pump together or just T-stat? consensus is do both.
2) indy or DIY? How competent are you with your hands? Are you detail oriented? Do you have experience doing other DIY projects? Do you have someone to help? How much is your time worth?
There are opportunity costs to DIY.
Entertaining America Since 1975
European Delivery July 26th 2011
ED Video:
ED Trip Report:http://www.bimmerfest.com/forums/sho...d.php?t=557294
335d| Deep Sea Blue| Black/Aluminum | Stuff | Gadgets | More Stuff | Power Whatnots | Auto-Verbing Nouns
BMWCCA #448878
Old 06-25-2013, 06:58 AM
Bemo's Avatar
Bemo Bemo is offline
Mein Auto: 2011 328xi
Here we go with penny wise, dollar cheap threads again.
No issues driving and paying for an expensive German car but when it comes time to maintain it, some folks belly ache. Do it now, both.
Rest assured, this isn't even the most expensive repair you may face. If you don't have an appetite for higher-than-average repair bills, sell the car and buy a non-German brand.
2015 911 Carrera GTS
2011 328xi
2011 535xi GT
BMW CCA
Old 06-25-2013, 09:02 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Great stuff. I kept looking for Jersey Joe until I remembered he joined much later.
Is that Jackson Browne sitting in on the piano? (There were only three hairstyles in the '70s so it's hard to be sure.)
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 06-25-2013, 09:11 AM
I've done a few diys before- pads, rotors, oil change, tranny and diff fluid drain and fill, basic suspension part replacement.... I found a pretty good looking DIY on the fest so I might just go ahead and get the parts from Tisher and have a crack at it.
Old 06-25-2013, 11:07 AM
No girls in a flatbed Ford. Yes, DLI.
www.bmwcca.org
Old 06-25-2013, 12:45 PM
Kamdog's Avatar
<- Bailey
Looks like him, and he co-wrote the song.
Old 06-25-2013, 12:57 PM
Pilgrim's Avatar
Car guy since 1968
I agree with every word in this post.
Old 06-25-2013, 01:32 PM
This post is nothing to do with being penny wise and dollar cheap. It's about making the smartest choice.... Wasting time is never smart and neither is wasting money. I have a budget to fix my car but why blow on something of you might not need it. Maybe you should no longer reply to "what would a smart guy do" posts if your only solution is to throw inefficient money at it.
