Old 06-24-2013, 07:30 PM
RexBeavers RexBeavers is offline
Rex Beavers
Mein Auto: 2006 325i and 2009 M5
Maybe It's Just Me!
This is my second attempt to figure out an ever growing "problem" with my 2006 325i. I had posted a few weeks ago about a lag on takeoff from a red light or stop sign. Tonight it started doing something new. The lag is still there, but now if I'm going down a hill and I lift my foot off of the gas pedal, the car slows down. As if I have the e-brake on a bit or there is an engine brake on the car. I was going down a pretty steep grade at 50 mph, when I lifted completely off the gas, I slowed to almost 40 in a matter of 10 or 15 seconds. This doesn't seem right to me! It really feels as if I'm putting the brakes on. I've tried this "transmission reset" procedure. Not sure if it did anything or not.....Oh, did I mention that the lag is still there? Any ideas before I take it to the shop?
Old 06-24-2013, 08:39 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
I don't remember - did you read codes?
Old 06-25-2013, 04:27 AM
Rex Beavers
CALWATERBOY,
I did not read the codes, not even sure how to do it. I do know that when you mess around with the button on the turn signal stalk, and you go beyond the reset features, there are a lot of different little bits of gibberish (letters and numbers). Are these the codes you are referring to, or do you mean OBD2 codes?
Old 06-25-2013, 05:00 AM
Banned
Mein Auto: 2007-335 HTC
are you using cruse control? the cruse control will apply the rear brakes going down a hill to maintain the speed, if you dont belive me, set the cruse to 70 on the interstate and use the lever to change the speed, if you decrease it to 55 it will apply the brakes
Old 06-25-2013, 06:02 AM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
Maybe It's Just Me!
The car downshifts when you let off the gas and begins decelerating? Is that what you're feeling? If so that's normal.
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 06-25-2013, 06:08 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
There aren't always codes; it's the first response folks on boards ask so it is easier to diagnose. It does sound like you have a transmission problem. How long have you had the car? Has it done this from the start or gotten progressively worse? Do you have an independent shop to take the car into for a diagnosis?
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 06-25-2013, 06:12 AM
CALWATERBOY,
You're flyin' blind here w/o a BMW code reader....guess at best.
Old 06-25-2013, 07:08 AM
thekurgan's Avatar
Bad Lieutenant
It's not going to cost anything NEAR the price of a BT to have this diagnosed.
OP, if you're concerned with the way the transmission is functioning, it will probably cost you some dough to have it properly diagnosed; I would not purchase any device at this point.
Ilse
Bruna
BMWCCA #453648
engine braking, lag
