transmission light came on for 10 minutes then off. would there be an error code ?? - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 06-24-2013, 08:05 PM
ericwest ericwest is offline
Mein Auto: bmw 1999 323i
the transmission light came on for 10 minutes..car would hardly move...no power...turned it off and 10 minutes later I started the car and it drove great...and no light...would an error code be stored??...if so where?...I did the obd2 scan and it shows no error codes..is there a different way to check for trans error codes??..or is it just the obd system...if its the obd system how come I can not find an error code when I scan??..
ANY HELP WOULD BE GREAT!!
Old 06-25-2013, 04:09 PM
BMW318i_E36 BMW318i_E36 is offline
Mein Auto: 2011 BMW 328i, 11 X5 35d
Scary ! Go show your mechanic and let us know, what it is ?
Probably TCM ?
Old 06-26-2013, 05:25 AM
Kamikaze1 Kamikaze1 is offline
Mein Auto: 318i E46
I have a very similar issue. Please read my thread posted today.
Old 06-26-2013, 05:26 AM
Mein Auto: 318i E46
Did you turned the key to Position 2 and then plugged the scanner?
Old 06-26-2013, 06:29 AM
I plugged the scanner in first...then turned on the key...should I have turned on the key first? ...I will look for your post
Old 07-02-2013, 04:36 AM
Mein Auto: 318i E46
My bad. You are right
You will have to plug the scanner first. Then turn the key to Position 2.
Cheers
Old 07-02-2013, 01:23 PM
k0l0k0l0 k0l0k0l0 is offline
Mein Auto: 1999 323i
I have a similar issue with my automatic 323i. Usually when the car has to downshift when going uphill, per say, is when the light comes on from time to time. I definitely feel a drop in power and the car tends to rev high. The car had almost 200k miles when I replaced the transmission and now nearing 300k, the problem returned. Although, my light turns off after about 1 min not 10min and it doesn't do it often. I surely do not know if we both have the same issue, but after all the miles and money, I just deal with the nuisance when it happens.
In short: I don't know what the issue is, but I am interested to find out as well!
Best of luck to you!
