Ugh troubles - Bimmerfest - BMW Forums
Old 06-25-2013, 03:06 PM
Averdi's Avatar
Averdi Averdi is offline
Mein Auto: BMW 325i 2006
Ugh troubles
I've now owned my car for about a month and have already put 1400 into it. What do you guys think? So far a water pump and thermostat (900)and now it has to get gasket valve caps(500) is this all regular maintainer for a bmw with 87k miles or do I have a lemon?
2006 325i
Red intake scoops, Red taillights, Red calipers, M3 rep wheels, M bumper, 28% tints, 6000k Angels & Fog lights, clear cornered headlights, Black and White emblems, Smoked side markers
Old 06-25-2013, 03:09 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
What are the "gasket valve caps"? Water pump seems normal at that mileage or even before; you got lucky
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 06-25-2013, 03:11 PM
Averdi's Avatar
Ugh troubles
I forget what exactly they are. Something with the gasket and the valves
2006 325i
Old 06-25-2013, 03:15 PM
Averdi's Avatar
Ugh troubles
Pretty sure it's leaking and needs to be fixed
2006 325i
Old 06-25-2013, 03:47 PM
thekurgan's Avatar
Bad Lieutenant
I have no idea what you're talking about here. Maybe put in text what your tech explained to you in exact terms. Looks like it's gonna cost you more than that tint job
Ilse
Bruna
BMWCCA #453648
Old 06-25-2013, 03:57 PM
Averdi's Avatar
Ugh troubles
Head gasket needs to be replaced. Got it and I know this car is killing me
2006 325i
Old 06-25-2013, 04:01 PM
thekurgan's Avatar
Bad Lieutenant
Ugh troubles
Head gasket is very rare.
Ilse
Bruna
BMWCCA #453648
Old 06-25-2013, 04:02 PM
Averdi's Avatar
Ugh troubles
Is it...that's not a good sign
2006 325i
Old 06-25-2013, 04:26 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Many buyers, thinking they're getting a steal of a deal on a fine, preowned BMW, discover they've bought previous owner's problems -and- owner sold 'cause ain't cheap.
You're well advised to invest in tools. DIY is excellent, both educationally and for personal confidence/self reliance. And if you need a mech, there's a lot less BS + whole lot more cooperation if you know whereof you speak; work with him. Advice offered here is that you let him charge a fair price - that'll def be below dealer cost.
Above, assume you mean valve cover gasket, what, $35 part? Hey, that's not a terrible job....this Saturday, try this DIY:
Old 06-25-2013, 04:30 PM
Averdi's Avatar
Ugh troubles
Above, assume you mean valve cover gasket, what, $35 part? Hey, that's not a terrible job....try this DIY:
2006 325i
Old 06-25-2013, 04:36 PM
DIY's abound.....invite some friends over; weekend job. Get a quality torque wrench!
Old 06-25-2013, 05:01 PM
Averdi's Avatar
Ugh troubles
My question to you , calwaterboy is do you think I have much more maintainer ahead of me with my milage? Do I have a lemon car?
2006 325i
Old 06-25-2013, 05:06 PM
aleks001 aleks001 is offline
Aleks
Mein Auto: 2006 BMW 325i
It's very rare, but doesn't mean it can't happen just like any other car. I'd take a guess and say they are probably going to replace your valve cover gasket not your head gasket, these are much more common. I'm at 86K and I'm pretty sure It's still the original factory valve cover gasket. But My oil filter housing has started to leak and I would get another opinion on your problem as this is usually the most common problem and it can make it look like something else. I would suggest you clean all the oil off with a rag and some degreaser spray and then after about a week or two of driving have a look to see where the oil is actually coming from before paying for potentially unnecessary repairs.
Old 06-25-2013, 05:19 PM
Aleks
I can tell you to expect the following on top of regular maintenance, so you can decide if its worth keeping.
1. Vanos solenoids (Apparently they can just be cleaned, did mine on the weekend, but we will see how that goes)
2. Oxygen sensors
3. Transmission leak from mechatronic sleeve
4. Ignition coils
5. Valve cover gasket
6. Oil filter gasket(s)
7. Water pump
8. Thermostat
These are the things I believe are common to our model. If you think this is too much on top of regular maintenance (bushes, spark plugs, brakes, rotors etc)
Then you best of getting rid of it, because more likely then not you will hit most of those issues not to mention a couple of random ones as you do with most cars.
Old 06-25-2013, 05:33 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
There were issues with the pass. air bag seat detection mat on these cars and a BMW recall resulted. The OP can contact BMW NA to see if his car was involved and remedied. Ref: BMW recall No. 08V-384...sometime in 2009 I believe.
If the OP's car is included, and was not recalled, it may still be repaired at no charge.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 06-25-2013, 05:54 PM
Averdi's Avatar
Ugh troubles
Nothing is really even leaking. Just when I turn my car on. It smokes and smells like burnt rubber. The mechanics said its from the oils leaking
2006 325i
Old 06-25-2013, 06:12 PM
Averdi's Avatar
Ugh troubles
2. Oxygen sensors
4. Ignition coils
7. Water pump
8. Thermostat
I've already fixed 1/2 of them hahahah almost there
2006 325i
Old 06-25-2013, 06:29 PM
Aleks
Like I said then, best to have a look yourself for the leaks.
Old 06-25-2013, 07:52 PM
thekurgan's Avatar
Bad Lieutenant
I think you hit it correct here with the valve cover gasket, I imagine the round gaskets surrounding the plug wells are leaking oil as well.
Ilse
Bruna
BMWCCA #453648
Old 06-25-2013, 08:02 PM
Averdi's Avatar
Ugh troubles
I understand I'm going to have to be paying more because its a bimmer and I'm completely fine with that. I just don't want to be in the shop every month for some new problem you know? It's been a month and 2 major problems happened
2006 325i
Old 06-25-2013, 08:11 PM
thekurgan's Avatar
Bad Lieutenant
How many miles on the car?
Do you have the past maintenance records?
Results to these questions may lead you to do some preventative maintenance; especially if past maintenance was neglected or taken to the BMW max interval. Do some research on Mike Miller's "Old School Maintenance Schedule" ... following this can extend major incidents and costs like you've experienced.
Also, if you aren't mechanically inclined, you will be paying more for what seem like simple tasks like fluid changes, belt changes, brake work, etc. Even BMW independent shops charge a premium for rates.
Ilse
Bruna
BMWCCA #453648
Old 06-25-2013, 08:13 PM
Averdi's Avatar
Ugh troubles
87k miles. And yes I have the records from bmw. It was taken care of . But I want to learn to do the easy tasks cause I'm only 18 paying for EVERYTHING
2006 325i
Old 06-25-2013, 09:23 PM
thekurgan's Avatar
Bad Lieutenant
Ugh troubles
Look into the old school and compare what's been done. Belts are a good start , power steering fluid, brake fluid, tranny fluid etch.
Ilse
Bruna
BMWCCA #453648
Old 06-26-2013, 12:10 PM
Averdi's Avatar
Ugh troubles
I think it is just the valve cover gasket. I don't have the confidence to do that. Do you think that the cable covet gasket is just from ware and tare or because the car wasn't treated right?
2006 325i
Old 06-26-2013, 12:34 PM
thekurgan's Avatar
Bad Lieutenant
Usually it's age, the material becomes a bit brittle, but I've not seen the material used for the N52 gasket.
Excessive heat can also contribute.
I'm sure DSX has seen/replaced many of them. On the M3s, they are silicone and very durable, I've never had to replace one due to failure, but rather just valve adjustments.
Ilse
Bruna
BMWCCA #453648
