Old 06-25-2013, 04:13 PM
asiansensation7 asiansensation7 is offline
Mein Auto: 650i/Mustang/Explorer
Where to buy spark plugs for 650i?
Hey guys, I'm going to take a shot at changing my spark plugs some time in the near future. RealOEM is showing me a Bosch spark plug with BMW part # 12122158252. I researched a little and found Bosch FR-7-KPP-332 is the matching Bosch part number? I couldn't find this spark plug anywhere except online... does anyone know if I can get this plug at Advance Auto Parts? (or a different plug that has the same specs?) Thanks in advance!
Old 06-25-2013, 08:50 PM
Nvm, purchased a set of these: http://shop.advanceautoparts.com/web...tion-_-General
NGK's website shows it as a compatible OEM replacement and I tend to be slightly more biased towards iridium plugs rather than platinum plugs. I'll follow up with a review after I change them out, though I'm not really expecting any difference from the OEM plugs.
Old 06-25-2013, 09:29 PM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
Bavauto.com or oembimmerparts.com is where I usually shop for maintenance parts but take a look at site sponsor section too. No opinion on which plug to get.
Old 06-26-2013, 06:26 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
Both Bosch and NGK's are stock at different times. Either will work fine. I did mine not long ago. Got them from bimmerzone.com because they are local to me and I can pick them up. It was around $10 a plug. Very happy with the results, you can search my past post to see pictures and impressions.
'07 650i Coupe - Black Sapphire Metallic
M6 bumpers, skirts & wheels
BMW M Cross Spoke Composite 101 Rims 20"
HUD, Comfort Access
Old 06-26-2013, 10:21 PM
reytran's Avatar
reytran reytran is offline
Nothing quite like a 6
Mein Auto: 09' 650i Cabrio
Hi,
Should I replace the coil packs too? I did that on my Audi, but it's an easy 4cyc. Not sure about our 6.
2009 BMW 650i Cabrio (daily drive)
2011 Audi A4 (groceries, bully, road trip, winter beater, family car)
BMW CCA ID: 473647
Old 06-27-2013, 04:58 AM
Mulchman's Avatar
Mein Auto: '07 650i
Originally Posted by reytran View Post
Hi,
I didn't and I wouldn't unless one or more were damaged or not working properly. But you'd have known if they were bad, the car would have given you a misfire code.
HUD, Comfort Access
