Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 06-25-2013, 05:27 PM
Sieralyn14 Sieralyn14 is offline
Mein Auto: BMW 528I
Smile One windshield wiper working??
I have a 2000 528I and recently one of my wipers stopped working. The driver side one works great like usual but the other one doesn't move. Any thoughts on what it could be??
Old 07-09-2013, 07:40 AM
Mein Auto: '06 AW 330xi
The motor is probably dead. I don't think the left/right motors have individual fuses, but I would start there. Might also want to check the relays as well.
Old 04-08-2014, 07:50 AM
agofberg agofberg is offline
Account closed at users request
Mein Auto:
Had the same issue. There's a nut that needs to be tightened that holds the wiper arm to the rotating drive shaft. Just tighten it and you should be good to go.
