Old 06-25-2013, 10:49 PM
HamidM HamidM is offline
Mein Auto: 2007 335 Coupe
BT Scanner Cable
$175 (Shipped) - I have a Bavarian Technic (BT) Scanner for sale. Normally retails for $287. Take full control of your BMW and see everything the Dealer can see including:
* reading/deleting extended codes
* check engine light reset
* tuner detection codes
* airbag light reset/codes
* high speed data logging of over 600 parameters including knock retard, adaptation values, O2 sensors, boost targets, etc.
* Plugs directly into your factory OBDII diagnostic port under your dash on the drivers side
* Display shadow faults and soft faults
* Display and record real-time actual values
* Activate components of the car for troubleshooting
* Reset service reminders
* Reset condition-based service indicators
* Send special commands to control units
* Show ECU information
* Access the latest BMW DCAN systems for 2007+ models
The most important use of this for me was the ability to see all/any codes that were thrown BEFORE taking it to the dealer.
This device will give you the peace of mind you NEED when you are still under warranty/CPO but want to add performance tunes/mods to your car. Do yourself a favor. Get the BT Scanner Cable and sleep well at night once your mods are installed.
