Old 06-27-2013, 12:59 AM
EmmaLove EmmaLove is offline
Mein Auto: 07 BMW 328i
Ticking sound with start
Hi all,
I just noticed the ticking sound with start, it was quiet loud.
I didn't notice it before, but noticed it when I started my car in quiet parking garage yesterday morning.
I'm thinking, it is a belt problem. I thought, it's normal to hear ticking sound with a first start in cold weather in the morning but it should go away with a short warm up.
But this ticking noise was quite loud and didn't go away with 2min warm up. It was it was ticking faster when I was running my car.
I have 2008 328i, around 30,000 miles, I rarely drive it and i'm a gentle driver. There's no warning sign, everything is up to date, I just changed my engine oil in march.
And the check screen says, "CHECK OK".
I'm out of manufacture's warranty now, I try do things on my own if possible =)
Do I need to take my car to shop?
This site is so great, and has been helping me tons! Thank you very much in advance to those experts *^^*
Old 06-27-2013, 04:56 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
The noise was diagnosed as an exhaust side bucket hydraulic valve lifter issue as well as a complete replacement of the head if needed. Search and you'll find a lot of information here, but basically this is going to cost you if out of warranty.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 06-27-2013, 05:48 AM
f30jojo f30jojo is offline
Mein Auto: 2012 X5 35d
Re: Ticking sound with start
Yeah that's a big issue, I had a 06 325 with the same problem. It will only get worse trust me. I swore they fixed this factory defect after 07. Believe it or not 'babying' a BMW too much is never good, and BMW NA fix for this is literally to drive the car harder and it will help. The valves will eventually fail though. When mine failed it was still under cpo but the invoice showed 3500 in repairs.... I promptly traded it as is for an E60
Sent from my LT18i using BimmerApp mobile app
Old 06-27-2013, 06:13 AM
Thanks for the replies,
Is it going to be really expensive? should I go to bmw dealer to fix this or can I just go to a reputable local shop.
If I drive it like this, would it harm my engine? thanks again!
Old 06-27-2013, 06:14 AM
chris328's Avatar
chris328 chris328 is offline
unbekannt
Mein Auto: 750Li Hi-Sec, '13 Actros
i had the ticking back on my 2008 E92. I just ignored it. Nothing happened. Others have brought theirs to the dealer, only to be told it's normal.
chris
Old 06-27-2013, 06:39 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Why does the valve fail exactly?
Old 06-27-2013, 07:11 AM
As it was explained to me. It's a factory defect. Air seeps in with the hydraulic fluid for the lifters, this causes the lifters to lash and eventually the lifter stops working all together. It happened to me one morning, cylinder 1 exhaust valves were stuck open.
Old 06-27-2013, 07:33 AM
thekurgan's Avatar
Bad Lieutenant
From what I understand, it's oil pressure related to the head design. Replacing the exhaust side lifters and a redesigned head is supposed to cure the problem of the lifters losing oil.
Ilse
Bruna
BMWCCA #453648
Old 06-27-2013, 07:36 AM
ericgt79 ericgt79 is offline
Mein Auto: 08 335i
this answered my questions, thanks
Old 06-27-2013, 09:46 AM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2013 X5
I was told by my mechanic to take the car for a long, fast drive and keep the RPMs higher than normal. The added oil pressure will help alleviate the symptoms... worked for me.
2013 X5 35i
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 06-27-2013, 09:55 AM
thekurgan's Avatar
Bad Lieutenant
The bleeding procedure; worked for me on the N54, but I hear it doesn't last on the N52 once temps drop.
Ilse
Bruna
BMWCCA #453648
Old 06-27-2013, 12:40 PM
katsudon katsudon is offline
Mein Auto: 2008 328i Coupe
i drive a 2008 328i as well. i experienced this same problem a while ago - probably around 30,000 miles too. i took it in to the dealer but they couldn't identify the problem. i tried to ignore it and after a while the ticking sound disappeared. i'm at close to 80K miles now and haven't heard it in years.
Old 06-27-2013, 01:22 PM
bocabimmer's Avatar
Could be that too... Happened during a Florida winter (50 degrees) and by the time it would have worn off it was spring (80+ degrees).
2013 X5 35i
2014 i3 BEV
