Old 06-27-2013, 05:13 AM
BigCo540i's Avatar
BigCo540i BigCo540i is offline
The Usual Suspect
Mein Auto: '12 X6 50i
New to us 09 328 - Question of oil service intervals
Just bought the wife an 09 328 with 30k. This is my first bimmer without an oil dipstick to check the oil . The manual says play along with the OBC says as far as changing oil, is this what you guys do or use your own change intervals? For instance on my 540 I use Mobil 1 0-40 and I change the oil at 7500 miles. I am planning to use same oil on the 328 as Mob1 is one of the BMW approved long life rated oils (ok?).
Also how do you reset the oil service, I have a peake tool for my '98 but doubt that will work for this car? I pretty much DIY everything and I have a solid Inde for times that I can't so I won't be taking her to the stealer.
Old 06-27-2013, 05:38 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Many of us follow the CBS system (15k or more). Many of us use shorter intervals (I use 7500 miles and BMW synthetic oil).
Resetting the indicators here: http://www.e90post.com/forums/showthread.php?t=384430
Old 06-27-2013, 07:31 AM
floydarogers's Avatar
Pedant and Curmudgeon
+ Mobil 1 0W-40 is good, many use it.
Old 06-28-2013, 06:57 AM
BigCo540i's Avatar
The Usual Suspect
Thanks for the feedback!
Old 08-13-2013, 05:07 AM
BigCo540i's Avatar
The Usual Suspect
I got spoiled using my oil vacuum to do my oil changes on the 540. I guess I have to break out the ramps and crawl under the car again.
Old 08-13-2013, 06:22 AM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
Yes I miss looking at the color of the oil on the dipstick.
Have you noticed what else is missing from your trunk?
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 08-15-2013, 08:27 AM
BigCo540i's Avatar
The Usual Suspect
Yep, a spare....what is this world coming to?
Old 08-15-2013, 08:49 AM
BiHoTTo115's Avatar
BiHoTTo115 BiHoTTo115 is offline
Mein Auto: 2006 330xi
That's why I bought a full-size same rim and threw one of the (least worn) old RFT's on it for emergency situations.
2006 330xi | 6AT | Navi | Premium | Cold Weather
