Old 06-27-2013, 06:17 AM
ktimov1 ktimov1 is offline
Mein Auto: 2006 328i
Exclamation Crazy Vibrations Accelerating
So there was some heavy rains and flooding when driving to work yesterday morning. At some points the water probably got a little over half the wheel high. I made it through with no problems.
On the way home however, I noticed vibrations when accelerating. Around 30-40mph there would be heavy vibrations, however if I release the gas pedal the vibrations would go away. And the car seems smooth at every other speed point, its just when accelerating and hitting 30-40mph. When I pass 40 the vibrations stop.
What did I break this time? I like how problems occur right after you opt out of warranty extensions
Car details:
2009 328xi with sports package.
Old 06-27-2013, 09:01 AM
Mark K Mark K is offline
Mein Auto: '17 GTI '16 981 CS
Car details:
What kind of vibrations? No, not good or bad, I mean vibrations from wheels or engine?
Do you feel more:
a) vibrations noticed first on the steering wheel, then less on your seat
b) vibrations noticed first on your seat, but almost nothing on the steering wheel
In case of a) you are probably very lucky and hit something under water and didn't feel the impact or lost maybe a balancing weight. In case of b) ... well, fasten your belt because it can be anything from $2 to $12,000.
_
2017 Golf GTI |Silver over tartan cloth| MT| Base S, no options. Oh, wait! ... It does have a spare tire!
2016 981 Cayman S | 6-speed MT| Active suspension | Sport Exhaust System | Torque vectoring (with LSD) | Sport seats + | Sport design steering wheel
2013 VW Golf TDI [CONFISCATED]
2011 E92 335i 6MT ZSP ZCW (ED May 17th 2010) [SOLD]
Old 06-27-2013, 12:25 PM
I feel it on the steering wheel and on my seat.. but if I had to choose, I feel it more on the seat.. So I assume my cost will be on the higher end of the range you provided
Old 06-27-2013, 01:48 PM
Maybe not. If you can't decide which one is better felt, I'm pretty sure you have a bent wheel, tire out of balance because it lost some of the weights in that water or (hope not) alignment coming because of the hit under the water.
I would certainly not expect any significant vibration on the steering wheel if it was coming from the engine/transmission/driveshaft.
How about you try tire shop first and let them check wheel roundness, tire balance and general alignment status? That shouldn't cost very much and you just might find the cause that happens to be relatively inexpensive to take care of ...
_
Old 06-27-2013, 03:39 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Automatic or manual transmission? If it's a manual, check the guibo.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 06-28-2013, 06:11 AM
Automatic
Old 07-05-2013, 11:16 AM
It seems as if the vibration has stopped and the car is now running normally... 2 days before my scheduled service appointment for this issue.. Wonder if any excess water dried up maybe?? Not sure whether I should cancel the appointment now or what. This is crazy
Old 07-05-2013, 02:15 PM
dlwjdwns1992 dlwjdwns1992 is offline
bmw4life
Mein Auto: E92 328i Coupe
hmm
If i were you, i would still go to the appointment at the dealer and tell them that it stopped but do check the things that needs to be checked.
Old 07-05-2013, 04:39 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Yeah you prob should....that clump o'mud dried up & fell off or washed off....
Old 07-05-2013, 08:15 PM
thekurgan's Avatar
Bad Lieutenant
Sounds like My Cousin Vinnie
Ilse
Bruna
BMWCCA #453648
accelerate, flood, vibrate, water
