Old 06-27-2013, 08:41 PM
Cruzin328i Cruzin328i is offline
Mein Auto: 2007 BMW 328i Coupe
Quick Suspension Question
Hi All,
I have an 07 328i with 111k miles. I just had the struts and shocks replaced with OEM as well as the front arms... The ride is much better, but it still seems to have more vibration than I remember around 70-80 mph. Is there something else that should be checked or is it just because my car is getting old? I also just put new tires on the front and the back ones are still good.
Thanks for the help,
Matt
Old 06-28-2013, 03:01 AM
Banned
Mein Auto: 2007-335 HTC
you could have a front wheel bearing going, I had a vibration that I could feel in the steering wheel on my 4runner at around 65 MPH, jacked up the front took both wheels off, when I would spin the rotors I could tell one side felt a different, and not as smooth, pulled the wheel bearing assembly and replace it, when I took the old one apart the race on one bearing had a rough spot about the size of a pea, replacing it solved the problem
Old 06-28-2013, 05:23 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Poor wheel balance usually has a harmonic @ 75 mph.
Old 06-28-2013, 08:02 AM
floydarogers's Avatar
Pedant and Curmudgeon
You had a lot replaced; did you do an alignment, too? I would do one if replacing the control arm bushings (which I believe you did.)
Old 06-28-2013, 08:44 AM
Yeah, thanks. It was the control arm bushings that I had replaced... I was thinking it is probably some issue with the wheel(s). The tires were balanced and the alignment was taken care of as well.
My rims are severly curbed so I was thinking there could be wheel damage? I trust the guys at my local shop and they said to bring it back in a couple of weeks to have it aligned again as the new suspension needs to break in. I will follow up with them. Thanks for your guys' help.
Old 06-28-2013, 09:32 AM
Could easily have a bent rim. Usually the person doing the balancing will notice it.
Old 06-28-2013, 09:43 AM
BiHoTTo115's Avatar
BiHoTTo115 BiHoTTo115 is offline
Mein Auto: 2006 330xi
Check for bent rim as Floyd mentioned (I know I have two that are slightly bent...threw them in the back). Also check for a humming noise when cruising on smooth asphalt between 25-40 or so mph, you'll notice it much more if slowing down from say 40'ish on smooth pavement. A sign the wheel bearings are going, about $50 or so a piece on oembimmerparts.com. I'd get a balance done as well AND an alignment since you did replace those control arms, but I'd wait until you do the wheel bearings as well (if needed, most likely a firm yes) as you'll need an alignment more likely than not after swapping those.
2006 330xi | 6AT | Navi | Premium | Cold Weather
Old 06-28-2013, 09:54 AM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
Hi All,
Matt
Have them check if your tire is out-of-round. Even brand new tires have defects sometimes.
Old 10-23-2013, 06:55 PM
***Update***
It turns out my local shop really did not know what they were doing or they had lazy staff. I ended up taking my car to the dealer. I had to replace 3 of my wheels/rims (they were bent) and I had to get a new camber bolt for the passenger side rear wheel. After replacing the wheels and adjusting the rear alignment (after the new bolt), it drives great.
Matt
