Old 06-29-2013, 03:55 PM
sofa6A sofa6A is offline
Mein Auto: Cars
Automatic car wash in 2013 X5: Neutral; engine ON or OFF?
Manual (page 305) says to place in Neutral, turn engine off, key in ignition (slot).
When you get to the end of the automatic car wash, you need to put foot on brake to restart engine and place into Drive.
Today, this almost caused me to get rear-ended in the car wash.
Can you leave the X5 in Neutral and leave the engine ON while going through an automatic car wash?
Thank you in advance for helpful information.
PS: I don't want a debate between hand wash and automatic wash in this thread.
PSS: I searched this forum and sub-forum - no answer to the question I am asking. Please no sage advice to "do a search".
2013 BMW X5 35P Alpine White over Cinnamon Brown | Convenience & Cold Weather | "Hers"
2012 Audi S4 Phantom Black over Moonlight Silver/Black | 3.0 V6 Supercharged | 6-speed MT | Sports Diff | "His"
2005 Dodge Durango 5.7 Hemi | Dirt Hauler
Old 06-29-2013, 06:58 PM
digdesign digdesign is offline
Mein Auto: 2008 4.8i
On my 2008, yes. I do it all the time. I assume the 2013 is the same.
I read that same thing in the manual and didn't understand why they suggested cutting the ignition. (I guess it's to prevent any system from automatically putting it back into Park, such as when you open the door while rolling)
- Mick D.
Old 06-29-2013, 09:07 PM
dicmd dicmd is offline
Mein Auto: 2013 X5, 2013 535iX
Neutral with engine on is how I have always entered the auto car wash. No problems.
Old 06-29-2013, 10:02 PM
Mein Auto: Cars
Thanks guys. I'll do that going forward.
Turning the engine off felt wrong/dumb/dangerous.
dicmd - you "popped your cherry" in this thread! Post count = 1.
Old 07-02-2013, 06:42 PM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 535i M Sport; 328i Wagon
Re: Automatic car wash in 2013 X5: Neutral; engine ON or OFF?
On. I am pretty sure the car will go into Park automatically if you turn off the motor, and steering will lock if you turn ignition off completely ( second push of the button).
Current BMW's:
2014 535i MSport Space / Black, ZCW, ZDA, ZLP, ZLS, ZPP, H-K and 704
2015 X1 28i xDrive Alpine / Black, xLine, ZCW and Ultimate
2015 X1 35i xDrive Black / Black, ZCW, Ultimate and Xenons
Prior BMW's
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 07-02-2013, 07:32 PM
If it's in drive it will go into park when the engine is shut off.
If it's in neutral it does stay in neutral. Presumably so that you can tow it, or at least winch it onto a flatbed.
- Mick D.
Old 07-02-2013, 08:19 PM
xx xx is offline
Mein Auto: E83 X3, F25 X3 and F15 X5
lol I just had to try it too. Came home into the garage and then I hit the off button. It sure went into P
E83 X3 | E70 X5 (sold) | F25 X3 | F15 X5
Old 07-02-2013, 08:27 PM
ktono ktono is offline
Mein Auto: '13 X5 50i
I hate the automatic drive-thru car washes, not debating quality, just the arses behind me. Three out of three for having the driver behind me honk when the brake lights come on shifting into drive at the end..!!!
Old 07-03-2013, 03:08 PM
Mein Auto: Cars
If the engine is running and the car is in Neutral, you should be able to shift into Drive without stepping on the brake. I tried this specifically after my near disaster in the car wash that started this thread.
Old 07-04-2013, 06:28 AM
RockChips RockChips is offline
Mein Auto: 2008 X5 3.0si
From neutral, my car requires stepping on the brake before shifting into drive. I tried this many times. I get an icon on the dashboard telling me to step on the brake.
Yes I started using the carwash.
Old 07-05-2013, 11:04 AM
Same here.
- Mick D.
Old 07-05-2013, 02:27 PM
cravi cravi is offline
Mein Auto: 2012 X5 35D
Smile
One thing to note is - Key has to be in ignition and in neutral - you can stop the engine and it won't go into parking mode. I have tried it and worked out pretty well...If you remove the key out and the car goes to Parking mode after 30 mins (safety precaution and clearly mentioned in the User guide)
Old 10-05-2016, 07:33 PM
nimooln nimooln is offline
Account Under Review
Mein Auto: BMW
yes you can
Old 10-05-2016, 10:04 PM
Milliwatt Rob Milliwatt Rob is offline
Fool on the Hill
Mein Auto: x5 xDrive 35d 2013
When in a tunnel type car wash where the car is pushed through by its wheels, I leave the engine running.
But in a "touchless" car wash where you drive in, stop the car, and the washing apparatus moves around and over you as you sit stationary, I go into park and turn the engine off. And restart it when it signals to slowly drive out.
Old 10-07-2016, 08:13 PM
Frankjake Frankjake is offline
Mein Auto: 328d, 545i, 550i
I know this is about the X5 but on my 2013 550 I put it in neutral and leave the engine running. It only takes about 3 minutes from start to finish on the auto car wash. Plus in hot weather the A/C stays running. I just sit and watch them dry it off, hand them a decent tip and I'm off and running.
Old 10-07-2016, 10:14 PM
robnitro robnitro is offline
Mein Auto: x5 35d e70 2011
Whats funny is that release from the older x5's was removed. The bottom of the trans has the screw you can push in to engage neutral without power, however.
But from the looks of it, it is the same mechanism as the old bowden cables used! So, when I feel up to it, I will make a bracket and use a bicycle brake mechanism to engage this neutral as it's really stupid to have to start! the engine just to put it in N. You would think that they allow you to put it in N without that but it's ONLY after a failed start.
