Old 06-30-2013, 01:05 PM
Moik Moik is offline
Mein Auto: BMW 320xdT
xdrive temporary deactivation
Hi, I would like to deactivate x-drive for short time and test purposes on mud, wet grass, snow etc. just to test how RWD makes so I can decide about next BMW.
Does anybody know, what is the easiest safe way do do this? Error msgs doesnt matter.
Old 06-30-2013, 01:26 PM
tturedraider's Avatar
Freedom isn't free!!
Can't be done.
www.bmwcca.org
Infidel335 Infidel335 is offline
Mein Auto: 2009 335xi
It can be done. There is a fuse that you can pull that stops the transfer case from sending power to the front diff.
JB4 G5 | KW V1s | muffler delete | BMS DCI | aFe air scoops | VMR v703 18x8
Old 06-30-2013, 01:27 PM
Please elaborate.
www.bmwcca.org
Old 06-30-2013, 01:30 PM
Pull fuse #26 5amp. The windshield wipers will go crazy while it's out but the car will be fully RWD.
Old 06-30-2013, 01:48 PM
Teemo Panda's Avatar
Teemo Panda Teemo Panda is offline
Bimmefest Plasti-Dip Guru
Mein Auto: E53, E46-M3, E70, F25-X3
If you do this, a shadow code will pop up~
Old 06-30-2013, 01:50 PM
A diagnostic tool can delete those codes.
Old 06-30-2013, 05:12 PM
iaebg iaebg is offline
Mein Auto: 328i xDrive Coupe
Is this solid info?
Old 06-30-2013, 07:12 PM
I haven't tried it myself but the guys over at e90post.com have and say that it does the trick.
Old 07-01-2013, 01:27 AM
Ok, fuse 26 and delete codes after...
Via cable it is not possible???
Old 07-01-2013, 01:59 PM
You can clear codes with a diagnostic tool.
Old 07-01-2013, 03:38 PM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
If you are saying "I do not want to pull a fuse. Does anyone know a way to disable the xDrive via a software code change instead?", it appears that the answer is "No".
Old 07-01-2013, 07:21 PM
Another thread on e90post.com claims that the JB4 can do it but I haven't heard anyone else make that claim or provide supporting evidence. Honestly an open diff RWD car isn't that much fun.
Old 07-01-2013, 07:30 PM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW-less for now
In a world of electronics, I doubt that it will work.
For the record, I owned for 3 years an Audi Quattro, 1 of them without the central driveshaft. Bad vibrations. It was in FWD mode and I preferred it ... in FWD mode.
Old 07-02-2013, 05:31 AM
Are you sure AWD has an open diff at the rear axle? I dont think so, but not 100% sure.
Is there any possibility of damaging the actuator motor? I guess fuse should be pulled out with ignition off or with battery disconnected...
Old 07-02-2013, 06:48 AM
Zooks527's Avatar
Yes, an xDrive car has an open rear differential, and uses the ABS sensors plus the brakes to control wheel spin in place of a limited slip differential.
Old 07-02-2013, 07:02 AM
Spining one rear wheel on the jack makes nothink with the opposite one. That's why I though there can't be normal open differential. Anyway, I will try fuse 26 and let here know.
Old 07-02-2013, 11:12 AM
Mein Auto: '06 AW 330xi
Yes fuse 26 for N52s and fuse 20 for N54/5s. This will disable all stability and traction control systems as well as some safety systems such as ABS. DTC, DSC, EBD, AWD, ABS, and a few other systems are disabled.
Your car will store multiple shadow faults when you do this so if you plan on taking this car to the dealer anytime soon, have a BMW scan tool handy. A JB4 or Cobb scanner will not work as that only clears the DME faults. You need a BavTech tool or an ISTA, DIS, INPA, etc setup.
I've done this before and there are no ill effects. Just don't do this with the engine on!
Old 07-02-2013, 03:28 PM
^Or tell them you blew a fuse...just find a blown fuse.
Old 07-02-2013, 03:31 PM
Kamdog's Avatar
Kamdog Kamdog is offline
<- met in Rome, named Mo
Mein Auto: 2008 535i
Why not just drive a car with RWD only?
535i, Monaco, Cream, Light Poplar, Comfort Seats, PP, Nav, ED.
Old 07-02-2013, 03:32 PM
Keepittrill's Avatar
Keepittrill Keepittrill is offline
My avatar is a selfie LOL
Mein Auto: 2011 M3 DCT
Or just save yourself the trouble and rent a RWD BMW?
2010 E89 Z4- gone and forgotten (;
2011 M3 DCT
'14 C7 Z51 3LT M7
20 and blessed.
Old 07-02-2013, 06:07 PM
AWD makes a lot of sense for those of use that live in a state with frozen water 6 months out of the year. It's fun to have RWD from time to time but not worth sacrificing the driveability of AWD.
Old 07-02-2013, 06:41 PM
pspressart pspressart is offline
Mein Auto: 2011 335i coupe
I agree about AWD. When I lived in Louisville, KY in a hilly area of town, my 2002 325xi made a lot of sense during the winter. We had just enough snow to make it needed. However, now that I live in S. Florida, I do not ever hear the 37 degree beep, let alone have snow, so AWD is superfluous. That's part of the reason I now have a RWD 3351.
Old 07-03-2013, 03:04 AM
Yes I am living in a hilly area and we are 5 months under snow. But I am living in a city and 80% driving on highways with no snow. So it is 1:1.
I borrowed RWD BMW but this is just a test on snowy parking place or so... I need to try it in hard conditions, where (I guess) I won't be able to succeed with FUSE 26 pulled out.
Old 07-03-2013, 04:38 AM
I did not have snow often, but there were several times when more than 8 inches or more accumulated. One of the great features in my XI was hill descent control. My unplowed local street would go down a steep hill to the main road. Having HDC kept the car from going too fast down that hill. If I had to live in an area with a lot of snow and I had RWD, I would get a winter set of wheels and tires.
