E30 (1982 - 1993)
Old 06-30-2013, 04:39 PM
Brickenfist Brickenfist is offline
Mein Auto: 1985 325e
Light problems
My left turn signal isn't working. It doesn't flash, but it clicks rapidly. Every now and then though, it starts to work again. My right turn signal works fine.
My head light on the left side is also acting up. The bulb is fine (it doesn't seem blown at all and its still intact) but it doesn't turn on. I tried messing with the wires, and then it killed my car. I have it unplugged right now.
I'm stumped and have no idea what to do.
Old 07-01-2013, 01:10 AM
Billwill Billwill is offline
Mein Auto: BMW E30 318i 1991
Clean the contacts on your left turn signal or replace the socket and the bulb. If that does not help then the ground wire may be bad....add another lead to the ground terminal and fix this wire to a clean metal chassis place.
The headlight....as above and check fuses.
A bulb that "looks" intact is often not...sometimes there can be an intermittent bad connection inside the bulb itself!
Old 07-01-2013, 02:27 PM
BMWFatherFigure's Avatar
Old School
+ 1 on above plus checking for damaged /broken wires and terminals.
Current:
E38 Parts Car
Previous:
Old 07-06-2013, 10:41 AM
My turn signal started working again all of a sudden.... Anyway, I should have checked my headlights better. The left light turns on, and when I turn on my brights the left lights don't turn on, but both of the lights on the right turn on. I'm so confused. I will try cleaning and checking connections.
Old 07-06-2013, 06:02 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 2001 540i sport/1994 525i
Light problems
Check the fuses. I believe the fuses numbered 1 and 2 are for the hi-beams. They should be 7.5amps.
If the connections/grounds/and fuses check out. Blame it on the signal stalk.
Old 07-08-2013, 11:36 PM
It looks like i don't have a fuse in #1 but borrowed another and that takes care of the hi beam problem. I just need to figure out why the right side doesn't turn on when I turn on my lights. Also, if I push down hard enough my left blinker works. Thoughts?
Old 07-09-2013, 03:50 PM
First time's Avatar
Light problems
Faulty signal stalk. Or loose connection at the stalk. Either way you need ot pull off the cover to investigate.
By right side meaning the right side parking lights dont come on?
Old 07-20-2013, 11:08 AM
Wow, so it was just another fuse problem. Fuse #14 was missing so now my low beams are working both sides. Now though, I can't start the car with that fuse in. When I start the car first then put the fuse in, the rpm fluctuates(spelling?).
Also, my left turn signal, if I push down enough, will work. Some sort of contact problem I'm guessing.
Old 07-20-2013, 02:02 PM
toybuilder's Avatar
toybuilder toybuilder is offline
Mein Auto: 89 325i 2dr&DucatiMonster
Do you know what the build date is on the car ? I have the factory electrical manuals for most of the E30's and most of the years/by build dates are different here and there.Let me know and I'll try and figure it out for you Fuse 14 causing the car not to start is strange to say the least.Hope to hear from you soon.
Old 07-21-2013, 04:56 PM
I do not know what the date would be or how I would go about checking it.
Old 07-22-2013, 11:59 PM
toybuilder's Avatar
Sorry I should have told you how to find it.If you open the drivers door there should be a MGF tag with info like weight and tire pressure but it also will have a build date for the car .
Old 07-28-2013, 07:54 PM
romeomike's Avatar
romeomike romeomike is offline
Running life's race...
Mein Auto: 91 318i
You can also plug in the last seven of your VIN at realoem.com and find the build month/year that way.
On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
Old 07-28-2013, 08:25 PM
toybuilder's Avatar
Wow, I thought looking at your car would be pretty easy ,guess I was mistaken.
