Old 06-30-2013, 09:13 PM
AdamG13 AdamG13 is offline
Mein Auto: 2016 740Li
Noise from seat belt merchanism?
Every time I hit a speed bump or go over uneven roads while accelerating I keep hearing this clicking/creaking noise from both the driver and passenger side b-columns. I can't tell if it's the panels or the seatbelt mechanism. It seems to have gotten more prominent as time has gone on, maybe because lubrication has worn off or the panels just settled from temperature fluctuations or something. Has anyone else had this issue? Wanted to be armed with as much info as I can before I take it in because I'm sure the boneheads at the service center will give me the typical "it's normal" or "can't replicate it, maybe you hear a higher range than we do b/c you're younger" nonsense.
2016 740i Singapore Grey
2014 M6 Citrin Black
2013 750i Mineral White
2011 750i Jet Black
2007 750i Monaco Blue
Old 06-30-2013, 10:21 PM
MCChuck's Avatar
MCChuck MCChuck is offline
Mein Auto: 2009 750Li
Sounds like it could be time to clean/protect the seals in the door jambs.
I've used aerospace 303 protectant and also used gummi pflege. Either one works great at protecting the rubber seals.
This should also stop the car from sounding like the car is flexing apart while going over uneven road surfaces or railroad crossings, speedbumps and the like.
Hope that helps.
Old 06-30-2013, 10:47 PM
Snorlax's Avatar
Snorlax Snorlax is offline
Mein Auto: ///M7
Hope that helps.
+1. Had this same problem and mentioned it to the dealer. The did the above, problem solved.
Old 06-30-2013, 10:52 PM
likegadgets likegadgets is offline
Mein Auto: 2017 750i
I have a similar noise on a 6 month old 2013 750i, driver's side only.
To me sounds like if something is loose inside the pillar.
Some days it is hardly perceptible and others is more pronounced.
I have not been back for the 1st service yet, but plan to bring this up.
I am intrigued by the post above about using Aerospace 303 protectant - where exactly should this be applied?
Old 07-01-2013, 05:40 AM
Deutsch100 Deutsch100 is offline
Mein Auto: 2012 Active Hybrid 7
My 2010 750i did this horribly, almost from the beginning! My 2012 AH7 had many fewer rattles and squeaks.....actually & sadly less than my 2012 Rolls -Royce (7 Series based) Ghost!!! Phantom.....SILENCE!! Build Quality is out of this world!!!
2013 Rolls Royce Phantom Sedan,
2013 Phantom Aviator Coupe, 2013 G63 AMG
Old 07-01-2013, 08:35 AM
M4XBMW7's Avatar
M4XBMW7 M4XBMW7 is offline
TTurboFest
Mein Auto: F02 (750Li)
Hope that helps.
Here you go saving the world again I will try the 303 protectant! Now where exactly do you apply it ? On the rubber door seals ? Spray and wipe off ?
Thanks guys
Old 07-01-2013, 10:14 AM
MCChuck's Avatar
Thanks guys
I would just use a MF towel and apply as per instructions.
I would dampen the MF towel, apply to the seals, then wipe off if the instructions say to do that.
Apply to anything made of rubber that you see(and don't see...bottom of door). As long as you are there why not dress/treat the boot that covers the wires leading from the body to the door?
Its is really amazing how much noise those seals can make when they are not happy.
For the doorjamb/rubber molding challenged, here are a few photos:
ID:	384406   Click image for larger version
ID:	384407   Click image for larger version
Old 07-01-2013, 11:22 AM
Thanks for the tips. Never would have thought the seals could be the cause. I'll order some on amazon and give it a shot.
2011 750i Jet Black
Old 07-01-2013, 12:43 PM
MCChuck's Avatar
If you can't find what you need on amazon, try detailersdomain.com
I get all my supplies from Phil.
He has a sale going thru the 4th of July.
Old 07-01-2013, 01:39 PM
M4XBMW7's Avatar
TTurboFest
Yep just order mine from them , thanks a lot again.
1 Item(s): $12.99
Discount(s): (details) - $1.95
Shipping: $8.46
Taxes: $0.00
TOTAL: $19.50
Balance: $19.50
Apply Coupon: JULY4
Old 07-01-2013, 02:58 PM
roots roots is offline
Mein Auto: 2017 X5 35i
I too am having the same noise from the B pillar. Thanks for the tip! I just ordered 303 and a bunch other stuff from Detailers Domain.
2017 X5 35i (Nov 2016)
2012 528i (ED March 2012)
Past:
2014 328i (Feb 2015)
2013 740i (June 2013)
2011 X5d (Sept 2010)
2008 550i
2006 530i (ED Oct 2005)
2003 530i (ED Oct 2002)
1999 328i
Old 07-01-2013, 03:03 PM
MCChuck's Avatar
1 Item(s): $12.99
Shipping: $8.46
Taxes: $0.00
TOTAL: $19.50
Balance: $19.50
Apply Coupon: JULY4
That is self restraint!
I usually find about $100 of stuff I could use/try every time I place an order.
Old 07-01-2013, 05:39 PM
I added some other stuff so I could get free shipping and when I was about to checkout, my total was close to $200 After an exercise in self restraint, I was able to get it under $100.
Past:
2008 550i
1999 328i
Old 07-02-2013, 06:12 PM
Great solution. The noise appears to be gone after applying the aerospace 303 protectant to the seals.
While the noise appeared to come from the eat belt mechanism, it looks like is was the seals
Got the 303 protectant from Amazon, free shipping because of prime, and avoided the temptation to buy more stuff
THANKS
