Old 07-01-2013, 03:03 AM
gibo58's Avatar
gibo58 gibo58 is offline
Mein Auto: 530i MSport
That old chestnut...vapor barriers
We have had a week of rain where I live and it seems the rear vapor barriers have finally failed (03 530i).
Unfortunately 3M don't sell the butyl tape over here anymore
I rang my local BMW dealer and they have a product they use and will sell it to me by the metre for $9 per metre
Anyone know how much is needed per door, I was thinking about 1.5m per door so 3m all up.
Was also looking at this product a mate at work showed me from Bunnings
http://www.bunnings.com.au/products_...bType=products
All advice appreciated.
Regards
Gibo
Old 07-01-2013, 06:29 AM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
Just use a heat gun and reuse the old stuff.
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 07-01-2013, 10:54 AM
Bennt771 Bennt771 is offline
Mein Auto: 2000 540i,89 Por 930,Vett
Go to a auto glass shop and purchase some butyl.Thats what i had to do.
Old 07-03-2013, 02:30 AM
gibo58's Avatar
vapor barriers
Thanks for the replies.
Unfortunately the auto glass shops down here don't use the Butyl tape anymore, 3M don't supply it in Australia.
I think my best best is to get the product BMW Australia uses, at $9 a metre the job should still be quite cheap to do, I would rather do the whole door again than try and re-use the old stuff.
Anyone know how much they used per rear door when they did theirs?
Old 07-03-2013, 07:27 AM
Solo12 Solo12 is offline
Mein Auto: e39 530i e28 535is(Sold)
I picked up some non 3M window weld from my local autoparts store you may have similar luck in Australia. It was called Ribbon Sealer and came coiled up in a flat box, kinda like a small pizza box but flatter. It was hidden on a bottom shelf, but I did find it.
As far as length goes looks like the box said it was 4.57m long and that did the two rear doors with none left over. Although I followed the OEM lines of the adhesive plus added a little more on two of parts of the door that had not had any before. So you can probably get away with less than 4.57m for two doors.
E39 2003 530i: SP, CWP, PP, Manual, Sunshades, Split folding rear seats, 17" Style 42s
E28 1987 535is: Manual, Bilstein HDs, 16" Style 5v2 (from e38)[Sold]
Old 07-03-2013, 09:03 AM
Burning2nd's Avatar
Under the lift arms
I used black Rtv silicone
15486372<-----
Old 07-03-2013, 09:08 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Ouch! How you gonna get the barrier off when you need to replace the regulator?
Old 07-03-2013, 10:54 AM
Burning2nd's Avatar
Under the lift arms
Silicone pulls away much eaiser then the oem stuff that's on there
15486372<-----
Old 07-05-2013, 12:41 AM
gibo58's Avatar
Vb
Thanks Solo, I will have a look at some of our Auto part stores and see, failing that I will get the BMW dealer tape.
Thanks for letting me know what length I need.
Cheers
Gibo
