Old 07-01-2013, 09:11 AM
crose6994 crose6994 is offline
Mein Auto: 2008 328xi
Engine trouble. thoughts?
2008 328xi
hello, vehicle has been good to me except for this past week. when i accelerate the vehicle starts vibrating and the check engine light will come on and it will act as if its in some kind of limp mode. i will shut the car off and back on and the light is gone and its normal again for a few days. any ideas where to start looking? thanks
Old 07-01-2013, 09:54 AM
floydarogers's Avatar
Pedant and Curmudgeon
Originally Posted by crose6994 View Post
2008 328xi
As we tell everyone (and you would have found it if you had bothered to search): There are only several hundred things that could be wrong. Get the codes read then maybe we can help you.
Old 07-01-2013, 10:02 AM
floydarogers, thank you for your reasonable response. i have been on this site for quite awhile with very few posts. all i do is search and read. just curious because its just seems odd how its an on and off again issue. figured someone might have a clue and or the same issues.
Old 07-01-2013, 10:15 AM
3two8iguy's Avatar
3two8iguy 3two8iguy is offline
Mein Auto: 2011 E90 328i sedan
A bit strong,wouldn't you say?
Life is a Journey,Enjoy your ride.
Old 07-01-2013, 10:24 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
No.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 07-01-2013, 10:43 AM
3two8iguy's Avatar
Originally Posted by thekurgan View Post
no.
"No soup for you"....
Old 07-01-2013, 10:45 AM
thekurgan's Avatar
Bad Lieutenant
"no soup for you"....
There is such a wealth of information here and searching WILL yield some results detailing what will actually BE helpful in self-diagnosing an issue. If there is a light, there is a code somewhere, it must be read. As floyd mentioned, there are so many variables to take into consideration when diagnosing these issues; the thread can become huge and really unhelpful.
Too hot for soup here anyway
Ilse
Bruna
BMWCCA #453648
Old 07-02-2013, 11:24 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Bump
Old 07-02-2013, 11:29 PM
sptt144's Avatar
The car is struggling under certain conditions...if it is, you have an ignition or fuel issue but my bet is on the coils (they are know to be defective) or injectors. My toss at you is a bad coil(s), or injector (because I had the same problem, especially when it got cold outside). This will cause the car to struggle with the limp mode kicking in. Stop and restart and you are good, right? I have a 94.37% "guess right" success ratio vs. code reading Please let me know if I'm right so I can adjust me Guess Rate Success % upwards again when you find out. Don't rely on silly old expensive code readers. Cal? Calwater? What is your input here sir?
Old 07-03-2013, 12:04 PM
thank you very much for your response. i was going back and fourth with bmw because the light went off so naturally they say nothing is wrong. day 3 and they are still trying to get it come back on.
Old 07-03-2013, 12:14 PM
tturedraider's Avatar
Freedom isn't free!!
2008 328xi
Sounds a lot like a failing ignition coil. Pretty easy diy.
www.bmwcca.org
Old 07-03-2013, 12:20 PM
ladderman ladderman is offline
Mein Auto: 08 Acura TLS 03 Cic
Know it all's
Don't you just love it when one of these know it all's scold you for asking a question?
Tell him to go into the men's room and get a hold of himself.
Ladderman
Old 07-03-2013, 12:57 PM
thekurgan's Avatar
Bad Lieutenant
Ladderman
Scolding?
I read the response as "don't throw away your money on parts until you get a definitive answer by getting the code read"; maybe you're a little too sensitive?
Ilse
Bruna
BMWCCA #453648
Old 07-03-2013, 03:25 PM
... just curious because its just seems odd how its an on and off again issue. figured someone might have a clue and or the same issues.
Ignition coil might be it, might be spark plug. More remotely, failing knock sensor, camshaft position sensor. Too bad no codes.
Back in early '90s, had a weird problem. Had to test drive with the tech in the car for them to figure it out, as no codes were set (back before OBD II). We're a little better off now, but only if codes are set and read. Hope you find it.
Old 07-03-2013, 03:43 PM
Too sensitive?
Scolding?
Too sensitive, I don't think so. I read the post as a condescending reply to a guy that had a legitimate problem. You could sense the exasperation in his answer. How about this? If it is such a major problem to answer a person civilly, then just refrain from typing out a reply.
You must own a BMW !
Old 07-03-2013, 04:55 PM
thekurgan's Avatar
Bad Lieutenant
.. but there is NO answer, that's the point. The reply was informative to get him the fastest answer and save the most money, while your post added nothing to the discussion and was meant to be negative.
I've owned many BMWs, I have participated for years ... because .... this is a bmw board.
Ilse
Bruna
BMWCCA #453648
Old 07-03-2013, 05:49 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Common 328i issue: VANOS Solenoids
But is it the answer? Will it cure your ill?
Yup, ya gotta read yer codes t'see if you're homin' in. That means a code reader capable of reading all the codes BMW has to offer...and then some! I recommend: Bavarian Technic -- for extra goodness, insist on the Beowulf Edition.
Ah! You are King of Geats, but keep a sharp eye for dragons....
Old 07-03-2013, 08:02 PM
Pilgrim's Avatar
Pilgrim Pilgrim is offline
Car guy since 1968
Mein Auto: 2008 E91 328xi Sportwagon
Read
the
codes.
Then report back.These doggone cars are so electronic that you need to use the information available to you via the codes.
Lots of guesses can be offered, but that's all they are until you get more information.
1983 Datsun 280ZX Turbo
2000 Jeep Grand Cherokee
2008 BMW E91 328xi Sportswagon
2009 BMW E92 328ix Coupe
