Old 07-01-2013, 05:02 PM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 1997 528i
Vacuum Connections to M52 Intake Boot
Hello all,
Almost done with my e39 project after swapping in an M52 from a 328i but I am having difficulty figuring out the intake air boot. The car is a 1997 528i 5-speed with Nov 1996 production date so I went on RealOem and put in the VIN to ascertain the exact part. It showed part #13541740931 and the diagram looks right since the car does have ASC.
When the part arrives however it has two connections. One fits the hose to my ICV perfectly but the other is a gaping 2 inch diameter hole that I have no connection for. The RealOem diagram shows only one connector for the ICV so I thought the supplier sent the wrong part but the part number on the boot itself checks out.
This car doesn't have the exhaust flapper so there are only a few vacuum hoses. I have accounted for the fuel pressure regulator, SAP control, and fuel evap control which all attach to the bottom of the manifold just below the throttle body. The only other ones are the CCV and brake booster hoses.
Anyone have any idea what goes in the massive 2 inch connection?
94 318I (Daughter's car), 96 740IL(current project), 97 528I(DD), 07 335I(Son's car)
Old 07-01-2013, 05:19 PM
jbonly21's Avatar
jbonly21 jbonly21 is offline
Mein Auto: 02 525I SPORT
Post a pic of the part, maybe I can help.
02 525I Sterling Gray, 18" M Parallels, M Tech bumper, Magnaflow Highflow cat, Resonator delete, 3" OBX muffler, H&R spring and Bills sport shocks.
RIP ALPINE WHITE 97 528I
Old 07-01-2013, 07:17 PM
black528i black528i is offline
Mein Auto: e90 330i
You are missing #12 Real OEM
Old 07-01-2013, 07:39 PM
When I bought the car the head and all the upper parts of the engine were in a series of boxes and I didn't get the original air cleaner. I do have the MAF tube and everything downstream from that. The part in question is shown in the link below. I will try and post some pictures. I usually have to go on Flicker and put them up there then link to them so it may take a while.
The boot is shown as #9 in this diagram on RealOEM http://realoem.com/bmw/showparts.do?...09&hg=13&fg=15
As you can see the diagram shows only one connection, but the part number on the one with two connectors is exactly the same. I wonder if this part has two versions and I need to specify which one?
Old 07-01-2013, 07:48 PM
jbonly21's Avatar
If the part in question is 9,
This is what you need # 12
Old 07-02-2013, 03:08 AM
OK, I see. What does part #12 do?
Old 07-02-2013, 06:11 AM
mjalloul11's Avatar
mjalloul11 mjalloul11 is offline
BMW forever
Mein Auto: 1996 528i 1999 MB C240
Part number 12 is a silencer for the intake. You can plug the hole where it goes for a bit more intake roar .
Old 07-02-2013, 08:11 AM
Mein Auto: e90 330i
See post #3, you are missing #12 the resonator (See Real OEM). If you are using the engine from a 328 (M52), you need the boot #13541703588 or if you have ASC+T #13541740073.
Old 07-02-2013, 08:15 AM
moots's Avatar
moots moots is offline
wat's dat noise
Mein Auto: '04 525i
Sent from my GT-I9070 using Bimmer App
Old 07-03-2013, 03:19 AM
OK, thanks for all the info. I didn't realize the 328 used a different boot.
Old 07-04-2013, 08:14 AM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
I liked the 328 lower intake better, because it's clean. I've gotten rid of my silencer so you know.
