What does the accelerator button do? - Bimmerfest - BMW Forums
Old 07-01-2013, 08:18 PM
Supagoat Supagoat is offline
Mein Auto: 14 X1 x28i MSport, Miata
I'm at 1150 miles and almost done with break-in. I've started to push on the accelerator more but still keeping it under 4k. A couple times I've pushed it all the way down to the floor and engaged the button at the end of the pedal travel... It seems like it downshifts and is obviously full throttle.
The question is: I drive in manumatic mode exclusively so is there any difference between manually shifting down and pushing the accelerator until I hit the button and hitting the button? Do I get 100% throttle before I've hit the button or only after? In manumatic mode do I need to upshift if I do floor it and press the button or will it do that automatically since it auto-downshifted? I know when I release the button it doesn't auto upshift.
Thanks! (I think I kinda hate the button)
Old 07-01-2013, 09:01 PM
floydarogers's Avatar
Pedant and Curmudgeon
The button is actually more for the transmission than the engine. The car interprets you pushing it as: "I need maximum power and torque RIGHT NOW.", so the transmission downshifts to the best gear, rev matches the transmission to the correct engine speed, locks the torque converter, and commands full throttle (not necessarily in that order.)
Result: bat out of hell mode.
In old cars it was called the kick-down switch.
Old 07-02-2013, 12:40 PM
nbercasio nbercasio is offline
Mein Auto: BMW 535i and BMW X1
Am I missing something? I don't see this "accelerator button" on my Xdrive Sport...
Old 07-02-2013, 01:03 PM
The button is at the bottom of the accelerator pedal travel. Push the gas pedal down lightly until you hit a stop. Then push a little harder and you'll push the button. Do it on a highway with nothing in front of you.
Old 07-02-2013, 03:06 PM
whitby whitby is offline
Mein Auto: BMW
It still is I believe. Push to the floor and the transmission will drop a gear or two. As you say it was assumed that you needed more power which usually equates to more revs to get the engine in its optimum torque band.
Cheers,
2015 Glacier Silver 428i Gran Coupe
2015 British Racing Green Mini Cooper S 4 Door Hardtop
2012 Space Grey 528i MSport - retired
2013 Valencia Orange X1 xDrive 28i Msport - retired
Old 07-02-2013, 04:21 PM
I celebrated hitting 1200 miles today by pressing the button. :-) I don't hate it at all. It works really well with manumatic because with the button pressed it shifts up by itself during acceleration. When I'm done I can manually upshift.
Now that I can really drive it I'm reassured that I made the right choice with the 28. The 35 would be faster, but the 28's still quick and I love the ZF8 transmission. I know any time I'm cruising that I can downshift 2 gears safely to get some power to accelerate. I love the character of the car. It just seems so calm under pressure and willing to do my bidding.
I'm still going to get the Dinan tune, of course. :-) More power is better if you can get it.
