Old 07-02-2013, 04:55 AM
worldsmart02 worldsmart02 is offline
Mein Auto: 335xi
Recommended Service
My car 335xi has 40 k miles know and its time for the oil service .
With the oil service and replacing spark plugs ,what else I should be looking into getting changed .
Is there any need to change the ignition coils when the spark plugs get replaced ..
Sent from my SPH-L710 using BimmerApp mobile app
Old 07-02-2013, 08:31 AM
ctuna ctuna is online now
Mein Auto: 325xi wagon
Google Mike Miller BMW for a maintenance schedule.
Its got a lot of interesting history in it to.
Coils should last to well over 60k or two spark plug changes.
I wouldn't replace them till they go bad or some higher mileage number if you feel the need.
Old 07-02-2013, 09:49 AM
Mein Auto: 335xi
Re: Recommended Service
OK I will check it out. Is that what you follow as for the maintenance for the car , instead of going with CBS.
Does the car shows any indicator when its time for the coils to be changed .
Old 07-02-2013, 09:55 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Not exactly...when they go bad you get a Check Engine light.
Have you had the cabin air filter changed yet? Brake fluid flushed?
Old 07-02-2013, 12:14 PM
I use Mike Miller as a guideline.
As some have said he practices Aircraft Maintenance in which you
change stuff before it fails. Some kind of compromise between his schedule
and the CBS with the realization that there are no such things as lifetime fluid.
The air Filters are easy DIY's.
If you have a tune you might consider doing things a little more often.
Old 07-02-2013, 02:17 PM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is online now
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Most of it is common sense or follow the cars computer & CEL. Common sense is generally things that are easy anyway. In the spring everything outdoors here turns yellow/green from the pollen fall. I change the cabin filters & intake filter each year when the pollen is done doing its thing.
Kevin
CURRENT:
2018 BMW 440M-Sport MPPK/MPE 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 07-02-2013, 02:42 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
This is the truth, especially in heavy pollen/mildew/spore areas.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 07-03-2013, 03:51 AM
Mein Auto: 335xi
Car got serviced what ever the CBS called for and I also got the coolant flushed on my own. KNow car has no warrants , wanted to do what's needed to get it running at least 100k miles without major issues.
I did look at what Mike recommends . I agree that it needs to be middle ground what's is actually needed and what would be nice to get done.
Old 07-03-2013, 08:31 AM
Mein Auto: '06 AW 330xi
This isn't necessary but if you're having slight fluctuation in idle, some hesitation, etc have your ports walnut blasted. This will remove the carbon build up in your N54 engine, which is common on all direct injected motors.
Like I said, it's nothing mandatory but can help improve throttle response and overall operation of the engine.
Shops charge anywhere from $350-500 for this service.
