Old 07-02-2013, 08:00 AM
bigblackseries bigblackseries is offline
Mein Auto: E39 5 Series
Question What is this steering column button?
Hi folks, feels good being here.
What role does this ON/OFF switch in photo play?
Cant seem to find information about it anywhere. Thanks
Old 07-02-2013, 08:07 AM
Ed Cheung Ed Cheung is offline
Mein Auto: E39
That should be something the PO did.
96 528i AT w/steptronic. => 97 540i w/ steptronic. =>steptronic deleted, 6MT installed.
Old 07-02-2013, 08:10 AM
BioGuy BioGuy is offline
****ie
Mein Auto: 540i
That looks to be aftermarket. Do you have aftermarket fogs or DVD player?
Could be a fuel pump kill switch- but that would be a terrible location for it.
Old 07-02-2013, 08:52 AM
There's a dvd drive for the navigation. Fogs too. I don't know if they're after market. I imported my 2000 model E39 from Japan. Thanks
Old 07-02-2013, 09:29 AM
****ie
Mein Auto: 540i
Because it is aftermarket the only real way to know for sure is to pull the column cover and trace the wires out.
Old 07-02-2013, 10:10 AM
Ermagerd's Avatar
Ermagerd Ermagerd is offline
bimmerphile
Mein Auto: e39
It's the ejector seat. DO NOT PRESS IT.
Old 07-02-2013, 10:18 AM
cn90 cn90 is offline
Actually it is the SELF-DESTRUCTION button, it came from the factory.
It is for frustrated owners after the warranty has expired.
Once the owner is fed up with the millions of issues (cooling system, vapor barrier etc.), just hit the button, walk away, the car will blow up in bits and pieces.
Problem solved.
See...smart engineer design at work!
Old 07-02-2013, 11:26 AM
Burning2nd's Avatar
Under the lift arms
That must be the CCv, maf rebuild button
Lol just push it
15486372<-----
Old 07-02-2013, 11:46 AM
tcbDE tcbDE is offline
Mein Auto: (E39) 2001 530iA M Sport
Drive up to 88 mph and then switch it on! Set the date and time of your destination on the navigation screen. And let us know when you get back!
Old 07-02-2013, 01:45 PM
musa's Avatar
musa musa is online now
Mein Auto: 528ia , X5 4.4 S, 335i cp
Imported from Japan you say? My friend, all your escapades are possibly public info. You have no secrets. That thing is disguised as a switch but is in fact a high-tech communication device.
Old 07-02-2013, 03:47 PM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
Come on guys you got it all wrong, that's the switch for the flux capacitor.
Old 07-02-2013, 03:59 PM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
this is the "Sport" button
bmw started this design in Japan and finally implemented in latest 550i M Sport and M5
Old 07-02-2013, 04:09 PM
Andreas540i's Avatar
Andreas540i Andreas540i is offline
Mein Auto: 1997 BMW 540i
Thats actually a decent place to hide a switch.
1997 BMW 540i
Old 07-03-2013, 08:59 AM
z168 z168 is offline
Mein Auto: 01 540i/6
Bumper parking aide?
Old 07-03-2013, 10:01 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Aftermarket heated steering wheel? Vibrating hand massager?
Q {BMW CCA Member #191509}
(SOLD)
Old 07-03-2013, 10:18 AM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
If it was my car it would be to turn all the tail lights out for when im being chased at night.
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 07-04-2013, 03:07 AM
C'mon guys, why not offer a reasonable answer for all to appreciate? I'm still afraid to push this switch.
Old 07-04-2013, 05:18 AM
It could be for anything, like BioGuy said your going to have to trace the wires and see what it's connected to, it could be anything. We're just guessing. Maybe aftermarket angel eyes?
Just push the button, the car isn't going to blow up.....OK so if we never hear back from you again maybe it did blow up!
Topaz, did you put a 1/4 stick in the trunk to celebrate the 4th?
2000 540/6 Slightly tweeked...everywhere
Old 07-04-2013, 05:31 AM
miotoo miotoo is offline
Mein Auto: F10 520d
Very intriguing option in a 2nd hand car with no access to previous owner. As said, if nothing is visible immediately you need to try trace the wires..
And my cliche comment here:
Its a wife silent/vibrate mode switch for those needed solitude moments of you & your car.
F10 520d Deep Sea Blue 11.04.2011/16:24
Retrofitted:
5DF Active Cruise Control with Stop & Go incl. Collision Warning with Brake Function /ver. 1
2TB DEC Switch for Normal / Sport / Sport+ Writeup: http://www.bimmerfest.com/forums/sho...d.php?t=685869
8TH SLI Speed Limit Info / KAFAS 1
5AD LDW Lane Departure Warning / KAFAS 1
319 Universal Garage Door Opener
6WA Instrument Cluster with Extended Contents
Old 07-04-2013, 11:08 AM
izoel izoel is offline
Mein Auto: 530i e39 2002
Re: What is this steering column button?
Congratulation.. officially you're now member of the voltes 5 team..
that button will turn your car into part of giant robot.. prepare to save the world..
Sent using BimmerApp mobile app
Old 07-04-2013, 12:11 PM
QSilver7's Avatar
We can't give a "reasonable answer" because it is not a regular/standard option. That button is an aftermarket install (which is what all the off the wall suggestions are all about)...and the only way to determine what it's for is to turn it on and watch/look/listen for something to turn on. What's to be scared of...what harm could come from turning a switch on? Then as suggested...if you can't see/hear/feel anything...then further discovery will be required (trace the wires).
Normally, if someone puts a switch that close to the ignition or steering wheel...it's usually anti-theft related, headlight related, audio related, radar detector related, heated seat/steering wheel related, etc. Again, we are in the dark just as much as you are since this was installed by someone we don't know. In fact, you're in a better place than us, you at least have a visual advantage...is there anything that looks like was once installed and now is removed? Or do you have other things in the car that are not standard (subwoofer in trunk, DVD player, aftermarket lights)?
(SOLD)
Old 07-04-2013, 01:17 PM
waehrik waehrik is offline
Mein Auto: e39 530i/5, e28 535i
I installed two switches that look exactly like that that on the bottom of my steering column. One of them came with my Laser Interceptor and I bought a second one to match.
One switch turns the unit on/off and a second trips the reprogramming into parking sensors only. Neither switch can be seen, only felt on the bottom of the column.
I use the on/off switch to turn the jammers off once I've slowed down. That way the officer gets a reading after a few seconds and isn't suspicious that I've driven by him without getting a reading.
Laser jammers are legal in all the states I travel through, but the second switch is there if I were to ever get pulled over and I'm asked what the things in the front of my bumper are. Once that switch is thrown they operate only as parking sensors (beep-beep-beepbeepbeep) until the unit is plugged back into a computer and reset. It just avoids any trouble.
Check in the front of your car and see if you have anything mounted in between your grills. You may have a laser jammer system or hardwiring for a detector somewhere. If you're lucky it's still installed.
