Old 07-02-2013, 10:07 AM
bekimx bekimx is offline
BEKIMX
Mein Auto: 2007 BMW 328i
Angry Driver's side window buttons not working
Hi all,
Yesterday, after a major downpour, I went into my car and tried to roll down the windows. Well, nothing worked, and I noticed a tiny bit of smoke and burning smell coming from the panel on the drivers side door where the switches are located. I automatically thought one of the wires in there got fried, due to who knows what. Anyhow, all the other window switches (passenger side, rear pax and driver side) work. Also, on that same panel where the window switches for all windows are located, there is the automatic mirror switch, which works fine. The windows also roll down with the auto lock/unlock feature on my car, so I know it is not the window motor. I took a quick look at the fuses and had a hard time figuring out which one powered the actual switchboard for the drivers side window, but they all looked OK. I've contacted my BMW "stealer" however they cannot see me until next week, which is a bit frustrating.
Has anyone had a similar problem, do you have any sugguestions, is it something that can eventually dry out (if in fact water got in there) and work again?
I'm trying to avoid going to the BMW stealer because I know they will probably suggest something outrageous, I wouldnt be surprised if they tell me I need a new door!!
Any help is much appreciated, thank you!
Old 07-14-2013, 05:10 PM
Switch Doctor Switch Doctor is offline
Account Under Review
Mein Auto: 87 saab spg
BMW Window Switch
Sounds like you fried the window switch itself. Before going to the dealer I would check here first http://www.switchdoctor.net/bmw-window-switch.html
Old 07-15-2013, 01:23 PM
BEKIMX
thank you switch doctor! and thanks for the helpful web site. Unfortunately though, the switch is not the problem. I purchased a brand new driver's side master-switch, tried that and nothing. I'm thinking it's either the wiring in the door panel OR the distribution box located near the fuses. The weird thing is the switch is getting lights and the mirror control works, just not the windows!
Old 07-15-2013, 01:37 PM
Mein Auto: '06 AW 330xi
Have you check the window regulator?
Old 07-15-2013, 01:55 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
If it is the button, it's not a major deal to pop the door panal and replace it, I had to replace a rear switch due to rattling; it's just a matter of being careful and ordering some new door clips. If you have water in the door, the vapor guard may be leaking, it should protect those components. Not too difficult to replace, you just need some butyl rubber as the bonding agent for the guard.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 07-15-2013, 04:08 PM
BEKIMX
BMW Window Switch
The regulator is fine - Window goes up and down with the lock/unlock function on the keys...just the switch on the door panel seems to be dead
Old 07-25-2013, 04:41 PM
Make sure the pins on the connector all have good contact. Just the slightest loosening could cause it not to function. So make sure there nice and tight.
Old 10-01-2014, 02:48 PM
funkmc83 funkmc83 is offline
Mein Auto: 320
Hi bekmx
Did you get to the bottom of this issue?
I am having an exact same problem.. would appreciate. thanks
Old 09-11-2015, 01:55 PM
pilot1981 pilot1981 is offline
Mein Auto: Bmw e91
where I can find electrical schema of BMW E90 mirror switch driver side PN 9132135?
I'm looking to solve problem of all led not working.
Inviato dal mio iPad utilizzando Tapatalk
