Old 07-02-2013, 12:44 PM
XZSpr85 XZSpr85 is offline
Mein Auto: 745I
AC (blower)coming on by itself
Has anyone experienced the air coming on by itself. The blower will just start blowing and I turn it off and maybe 10 minutes or so it comes back on. Is there anything I can do about this or does anyone know what causes this to happen?
Old 07-02-2013, 02:15 PM
BimmerBrad7's Avatar
BimmerBrad7 BimmerBrad7 is offline
Mein Auto: 05 745 LI, 05 Acura RL
Same thing happens to me. Randomly comes on when i have it off, like when im driving with the windows down. It also doesnt blow full power and then sometimes it will. I've been told its the battery. Mine happens to be on the low side as it will say "recharge battery" if i leave the key in the ignition for longer then a min or 2 without starting. A low battery can cause several strange things to happen as these cars are very finicky.
2005 BMW 745 LI Sapphire Black
22's, AC Schnitzer Kit, H&R Lowering Springs, Tinted tails and Signals, AC Schnitzer
Carbon Door Pillars, Cross Drilled and Slotted Rotors, Tuner Mod, Tinted Windshield,
30% Tint all the way around, and some other stuff I forgot.
Old 07-02-2013, 03:11 PM
Jsedita74 Jsedita74 is offline
Mein Auto: 2006 750LI
its a coding issue .. you can have the car coded to not do that .... contact okee at triple coding codemycar@gmail.com. i had same annoying thing happen everytime i turned her on and he coded it for me not to do that anymore ....
Old 07-04-2013, 04:13 PM
mokh mokh is offline
Mein Auto: BMW 735 2002
Re: AC (blower)coming on by itself
i had that issue w while back. when i turn off the ac, after a couple of potholes it comes back on by itself. i figured it might be a problem with the "off" button being worn out but then it just disappeared by itself.
Sent from my GT-N8000 using BimmerApp mobile app
Old 07-04-2013, 11:02 PM
CNote750Li CNote750Li is offline
Asanti Edition BMW
Mein Auto: 2006 750Li
I thought I was the only one with that problem. As I'm riding with the windows down the ac will just come on, I turn it off and 10 min later it's back on.
Sent from my MB860 using BimmerApp mobile app
Old 07-05-2013, 04:18 AM
wucrew wucrew is offline
Mein Auto: 2011 E70 X5
x2
hitting big bumps would trigger my A/C back on
Old 07-09-2013, 12:26 AM
Mirage9940 Mirage9940 is offline
Mein Auto: 2002 745i
Same here guys is it normal?
Old 07-09-2013, 01:53 AM
Piers1989 Piers1989 is offline
Mein Auto: E65 745i
I think the controller panel just starts to wear out a bit.
On mine the fan control dials occasionally think they've been turned when they haven't, and this happened on my old car too.
I just spin them a bit before I put it back on auto and it usually behaves for a few weeks
Old 08-28-2015, 05:08 AM
Jdubbs750li Jdubbs750li is offline
Mein Auto: 2006 750li
Wow so it's a coding issue! I'm glad to hear that. Sheesh lol
Old 08-28-2015, 10:49 AM
FlylowTX FlylowTX is offline
Fixed his own HPFP
Mein Auto: '04 760li '01 750il Sport
I don't think its a coding issue. Mine would change the fan speed setting by itself, turn on and off, and just generally act annoying. Replaced the climate control module with a used one (under $100) and the problem went away.
Old 08-28-2015, 11:30 AM
@flylowtx I'm going to take my car to a specialist and see what's up. Ty
Old 08-28-2015, 04:50 PM
MBAMF504 MBAMF504 is offline
Mein Auto: 745Li
Mine would do it periodically sometimes when i get it the car the a/c would automatically come on sometimes i would have to turn it on manually in other cases the a/c would be on but the blower motor would not kick in until about after 5 or 10 minutes i was told by a tech at an indy BMW shop that the resistor on the blower motor is on its way out
Old 08-28-2015, 04:54 PM
Oh ok
Old 09-26-2015, 02:11 PM
Bikeferg Bikeferg is offline
Mein Auto: BMW 530 xi
Whatever happened with the folks having issues?
My 2007 530 xi when the A/C is turned off, will turn on itself after about 2 or 3 minutes. Yesterday, the fan would not go below a medium setting even when the control knob was turned all of the way down. The A'C fan wouldn't turn off when the car was turned off for several minutes.
Is this an A/C fan control module or something different?
Ferg
Old 09-26-2015, 02:15 PM
for me it wasnt the module or any of the devices that have to do with the ac. it was the control knob itself. it tends to get worn down and due to its design it becomes unresponsive. mine would usually turn back on when i hit a pothole or a speed bump at a relatively high speed. check for codes before u go around changing anything though.
