Old 07-03-2013, 10:58 PM
j0nblayz's Avatar
j0nblayz j0nblayz is offline
Mein Auto: F10
Check Engine Light - Radiator Outlet Temperature Sensor
Need some help guys, so my electrical fan kept running full speed on my 2003 540i, so after doing some research thought i had a bad coolant temp sensor top of the radiator hose. So i removed the intake box, and unplugged the cable from the sensor to see if there was any rust or leak. However after plugging in the cable back into the sensor, my check engine light turned on, but my fan now runs perfectly fine. My peake reader showed that i had code 0F7D - Radiator Outlet Temperature Sensor. I ordered a new sensor from ecstuning and swapped out the sensor and reset my check engine light. However my check engine light keep turning back on with the same code.Now im wondering if unplugging the cable caused some kinda of issue. I checked the connections, theres no rust of corrosion. Maybe i stripped/ripped the cable? anything else i can check for?
Old 07-04-2013, 04:28 AM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Need more info.
Does your Aux fan run at full speed when the engine is cold and the AC is off?
What about when it's cold and you switch the AC on?
I've had my lower sensor disconnected and didn't get any codes.
2000 540/6 Slightly tweeked...everywhere
Old 07-04-2013, 09:51 AM
j0nblayz's Avatar
Mein Auto: F10
Ever since i tripped the check engine light, the aux fan has been working prefect. Only on the initial startup i get the full aux fan speed, then slows down. I havent had it go full blast though during ac or driving.
Im thinking maybe i had bad luck and got a faulty sensor. Or maybe the cables were worn out and when i unplugged it, it shorted somewhere on the cable. Anyone know how to test for short?
Old 07-04-2013, 12:30 PM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
On my X5 I had the dual temp sensor giving fits affecting the aux fan, and having overheating issues. It's the one on top of the WP. One element was toast.
The only way to determine is by using GT1 or INPA.
Old 07-04-2013, 10:10 PM
j0nblayz's Avatar
Mein Auto: F10
issue fixed, someone suggested to check the connector itself, i pulled back the boot on the connector and the wire was ripped from the connector. Put in a new wire and code is now finally cleared!
