Old 07-04-2013, 05:13 AM
sle39lvr sle39lvr is offline
Mein Auto: 08 E90
N52: Weeping Head Gasket?
This is a N52 with over 80K miles.
I had my valve-cover gasket replaced at 50K and around the seal is clean and grime-free.
I also had my exhaust vanos leaking and it made the surrounding area grimy and oily. I replaced it and clean the area around it.
However, I recently notice the area around the head gasket is very dirty. Grimy and oily. I got a reply from another forum that this would be a 'weeping head gasket. How can I check for this?
The car is under CPO warranty, I just want to be sure if I go in, because they will try what ever they can to get out of it..
Thanks in advance
Old 07-04-2013, 05:48 AM
Mein Auto: 08 E90
Here are my own images to supplement:
Old 07-04-2013, 08:32 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Looks like dirty to me, perhaps you're in a humid climate and the rubber belts are dusting? If you can, use an APC on a cold engine, let it dwell a bit, then give a rinse, you'll be able to better tell where it is emanating? This will also help the techs if you decide to bring it in, as they will most likely clean the areas as well.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 07-04-2013, 08:38 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by sle39lvr View Post
This is a N52 with over 80K miles. I recently notice the area around the head gasket is very dirty. Grimy and oily. I got a reply from another forum that this would be a 'weeping head gasket. How can I check for this?
Look for a broken head bolt. Aluminum, aren't they?
Old 07-04-2013, 09:16 AM
Mein Auto: 08 E90
How can I look for it?
Old 07-04-2013, 09:47 AM
And if that ain't it, remove the valve cover to check head bolts.
Old 07-04-2013, 04:26 PM
Mein Auto: 08 E90
Thanks I will check for those.
Old 07-07-2013, 01:16 AM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Re: N52: Weeping Head Gasket?
Is that why its referred to as the Hyundai engine in a bimmeer? Why would they do that?
Sent from my SCH-I405 using BimmerApp mobile app
Old 07-07-2013, 08:19 AM
thekurgan's Avatar
Bad Lieutenant
Originally Posted by sptt144 View Post
Is that why its referred to as the Hyundai engine in a bimmeer (bimmer) ? Why would they do that?
Um, what are you talking about here?
Ilse
Bruna
BMWCCA #453648
Old 07-07-2013, 11:06 AM
sptt144's Avatar
That was meant for another thread. Have no idea how I posted it here. My apologies...
Old 07-07-2013, 12:59 PM
thekurgan's Avatar
Bad Lieutenant
hehe, no sweat, I was trying to see where it would fit in the other threads, the mobile app does that sometimes.
Ilse
Bruna
BMWCCA #453648
Old 07-08-2013, 08:56 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
Put some UV dye in the oil then check with a black light. That is the gold standard for identifying the origin of oil leaks.
Old 07-21-2013, 10:52 AM
Mein Auto: 08 E90
I took the undercarriage out and noticed all this oil dripping:
Should I go to dealer and have it checked under CPO warranty?
Old 07-21-2013, 12:01 PM
thekurgan's Avatar
Bad Lieutenant
I would take it to the dealer.
Ilse
Bruna
BMWCCA #453648
Old 07-21-2013, 01:12 PM
I should say so.
I want your lift!
Old 07-21-2013, 01:16 PM
Mein Auto: 08 E90
Anyone here has experience with a repair like this with CPO? I know there is a $50 deductible, but my dealer is really tricky and will try everything to blame it on me and get out of it....
