The X5 SAV Forum
Old 07-04-2013, 02:25 PM
Shogan Shogan is offline
Mein Auto: '08 535xi or '02 X5
Stall bad gas or fuel pump?
'02 X5 3.0 with 175k. Drove during 100+ weather but car not overheated it stopped running and couldn't get it started at the light. Had it towed home. Has less than 3 gallons of gas (idiot light off). It started and ran for 3 minutes. Put additive and 5 gallons of 91 into tank and ran without stopping for 8 minutes so I drove to get more gas and ran for another 15 minutes. Everything is running as usual for the last two days 60 miles. I don't want to leave my wife and kids stranded again. Bad gas, bad fuel pump, or something else?
Old 07-04-2013, 09:24 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Check engine light?
It could more than those listed.
Fuel pump seems logical, but you should get codes read for further diagnosis.
Old 07-06-2013, 05:05 PM
Check engine light not on. Still running good.
Old 08-03-2013, 01:08 PM
Problem found. I replaced the fuel filter (it had 178k miles) and the lines Inside the fuel tank that take gas from one of the saddlebags on the driver-side siphoning gas to the passenger side where the fuel pump using the return fuel line.
