The X5 SAV Forum
Old 07-04-2013, 04:24 PM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is offline
Nothin like an E34
Mein Auto: 95 540i B/B
Self-leveling suspension PROBLEMS
My buddy has an X5 that he recently had to replace both rear air bags in because they both blew out. When he turns the X5 on the rear pumps up and does not quit pumping. That is why he had to replace the air bags, and it is still doing this, he cant drive to work, so i drive him, because he is afraid of blowing the bags again. What could cause this, i did not find much info on google.
Old 07-04-2013, 10:19 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
The source of the leak is above the bags. There are hoses that run along under the spare, red, and blue.
The circlips above the bags themselves after installing should be snug and snapped. If the pump is running non stop the leak is bad.
Also if the pump runs after about a minute and senses no movement in vehicle height, it will stop automatically.
Check the system for leaks with soapy water (mildly) and move forth from there. You won't blow new bags.
Old 07-05-2013, 07:04 AM
Nothin like an E34
It never stops pumping, the bags are new, i found no leak, but will look again.
Old 07-05-2013, 08:07 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
You gave no model/model year/build date info...nor did you mention WHICH air suspension your friend has. The X5 could have a rear SLS system (single-axle)...or a dual-axle system. If they have the dual-axle system, then obviously the front air shocks need to be considered., as well
If we assume the X only has the single (rear) axle system, as mentioned above, all the hoses need to be considered...as well as the "reservoirs" and the tubing that runs to & from them, too:
_
Q {BMW CCA Member #191509}
(SOLD)
Old 07-05-2013, 08:21 AM
Nothin like an E34
Im sorry i dont know all the systems im just trying to help someone out. He only has two airbags on the back. His build date is 04/2000. So 2000 model year x5
Old 07-05-2013, 01:18 PM
QSilver7's Avatar
Thanks...do check all the lines that run between the reservoirs, springs, & air supply (basically the components illustrated above in the EHC I system). Good luck.
(SOLD)
Old 07-05-2013, 01:27 PM
Nothin like an E34
I checked all lines on my break with soapy water, looked for almost an hour(1 & 1/2hr break time). No bubbles. I started the x and it ran for about 20min and the compressor NEVER shut off. He said he tried to pull the fuse but it did not help. I didnt check which one he pulled to make sure it was the right one though. Could it be the computer, or a sensor not shutting off the compressor? Im starting to think there could be a leak in the compressor unit itself.
Old 07-05-2013, 01:41 PM
boramkiv's Avatar
Propellers Up Front
Is the rear if the X sitting on the "wheels" (bump stops).
Is it all the way down at the rear?
It looks like time to take out that air supply unit and do some checks. See if any air is actually being delivered.
The only reason I said it stops is because when I had an actual hole in my right rear bag the day my wife came home with the low rider, there was a self level suspension inactive message. I turned it off, let her in the house, sat her down, took off her shoes, and went back out.
When I started the vehicle I immediately heard the compressor working, while there was no warning on the dash, but I also immediately heard a loud hissing from the right rear. It ran it in that state for a good minute, and then it stopped with the message showing on the dash as it stopped. I thought I killed the compressor, but I did it again to ensure all I needed was bags, but this time a had the negative battery post waiting to be disconnected, as this time I just unlocked the vehicle to activate the compressor rather than have the engine running.
Make sure the level sensors aren't stuck, you've already checked lines and accumulators, make sure you check the bags and installation again as they should have a nice roll fold and tucked in there respective spots. Make sure the bags are good, Arnott yes?
Ensure the very top of the bags where the circlips are installed are good with no bubbles.
When all checks out, the air supply unit should be next.
Old 07-05-2013, 02:22 PM
Nothin like an E34
Its all the way down overnight. No message on the dash. I may just try to find the assembly, i will double check the installation.
Old 04-12-2014, 01:12 AM
jadekleinhans jadekleinhans is offline
Mein Auto: E53 Sportpack
having hassels with my rear suspension
My rear suspension had sagged overnight,the car has been parked for quiet a while and collected it yesterday,drove fine.
Could there be a leak in the lines that lead from the compressor to the bags or could the bags possibly have a hole in where the air leaked out.
pls advise if u can,
the vehicle is a 3.0 d 2003 model.
Old 06-13-2016, 09:00 PM
John03X5 John03X5 is offline
Mein Auto: 03M3, 03X5
Air Springs Can Leak Down VERY Slowly--Even New Ones
Vehicle: 2003 X5 4.6is, 78,500 miles
Symptoms: Air suspension goes low every few days--specifically the left air spring bleeds down over several days. Air compressor would run once every few days, air spring leakage, pumps back up within one-minute run-time of compressor
Troubleshooting Approach (Phase I): Based on forum posts and Internet research concluded that left air spring most likely leaking since only one side leaks down and immediately re-inflates when air compressor kicks on.
Initial Repair: Replace both air springs with new Arnott-brand from rockauto.com. ($250 total)
Initial Results: right air spring--holds air and works as-new; left air spring--leaks air immediately after install, going completely flat within 8 hours. Left spring pumps up normally each time but leaks down within hours after vehicle parked.
Troubleshooting Approach (Phase II): Swapped left and right lines, reservoirs, solenoids until everything from left side was on right side and vice-versa (with the obvious exception of the solenoid connectors which must remain on their respective sides in order to insure correct leveling is maintained). No change in behavior--therefore, conclude that brand-new Arnott air-spring on left side is defective.
Secondary Repair: Replace new left-side air spring with ANOTHER new left-side air spring.
Secondary Results: All good, no more leak down.
Conclusion: Even a brand-new air spring can be defective. It was especially disconcerting because the defective air spring was on the same side as the failing original air spring. Conclusive diagnoses was reached only after swapping all components--except springs--from left to right and observing that the left air spring was still leaking down even though it was connected using all components from the right side (except solenoid wire connections).
Secondary Conclusion: I would find it difficult to recommend Arnott air springs for any application given their inability to produce 100% reliable new components.
