2006 whining noise - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 07-04-2013, 03:32 PM
1hander 1hander is offline
Mein Auto: 00 540i M-06 X5 4.4
2006 power steering pump whining noise.... fixed
its been getting louder.... i think its the power steering pump.. if i rev, the sound increases and changes frequency...turning the steering wheel causes only a small change in the the sound, that couuld be because of the engine loading up from the steering pump.
the reservoir is topped off. anybody experienced something like this and have a prognosis for me. maybe an idler wheel or tensioner...but it really sounds like the pump... let me know what you guyts think
Old 07-04-2013, 08:37 PM
Zulu95's Avatar
Zulu95 Zulu95 is online now
Mein Auto: 2001 X5 3.0L
I would have the idlers/tensioner checked and the water pump as they are common failure points. They tend to do a self destruct that takes out lots of other thin gs when they go.
GL
Old 07-05-2013, 02:42 PM
wmgerlach wmgerlach is offline
Mein Auto: 2005 X5 4.4
i would check idler pully and tension pullys and the water pump its a bmw so anything is posible around 100k
Old 07-31-2013, 04:11 PM
desertviking desertviking is offline
Mein Auto: 2006 X5 4.4
2006 whining noise
I had the same issue
Had the pulleys and belts replaced to no avail.
They fixed it by replacing these two identical parts and forgive me I forget the name of them. I think they sit on the crankcase. They are round about 3 inches wide and have this rubber diaphragm that cracks and lets air in.
There is a hose hooked up to each one.
They were pretty cheap.
Hope that helps.
Old 07-31-2013, 04:13 PM
i will be checking all of those
Old 11-23-2014, 05:05 PM
so i still havent found out what this noise is...the pump is new..3 months old now, the sound nver went away from the old one... maybe one of you has hear this sound,..
its not the alternator, i just replsaced that yesterday with a new valeo unit... and i replaced the belt and the alt idler pulley, and suction hose, water pump is new and silent ,..... ive gotten under the truck and im 99 percent sure that the sound ids coming from the pump... it doesnt do it on cold start, it starts once it has warmed up..
parts i have not replaced are the
alt tensioner idler wheel,
high pressure hoses
servotronic steering rack
a/c tensioner pulley
power steering reservoir
here it is..is not that loud but you can definately hear it
Ret. SSG Gonzales
5th SFG
De Oppresso Liber
Old 11-25-2014, 03:46 PM
problem fixed.... before i started buying ither prts, i decided to change the power steering fluid out. i had four quarts of mobile1 atf sitting around
i removed the reservoir and used laquer thinner to rinse the filter out thinking maybe the filter is a little clogged but nothing there...
i disconnected the suction hose down by the PS pump... and had my on keep turning the steering wheel from lok to lok till no more oil would come out .... then reconnected... refilled with 1 new quart... start engine to get all the air out.... then drain again ...lok to lok...refill ..start to get asir out...then drain again
i did that a total of four times to get as much oil out of the radiator cooler section as possible...then on the fourth one i refilled to capacity and drove around to get it hot and
voila no more noise,... i guess the oil had just gotten to think is all i can guess...it was not dirty in the least ..but the noise is gone...
Ret. SSG Gonzales
5th SFG
De Oppresso Liber
