Dont mean to be a pain - Bimmerfest - BMW Forums
Old 07-04-2013, 05:31 PM
RideForeign RideForeign is offline
Account closed at users request
Mein Auto: 2007 328xi
Exclamation Dont mean to be a pain
i do my own oil changes and work on my car alot. I got an oil change done by a midas by my house nd it was absolutely black when i changed it 1000k after i got it done. since then i dont trust any1 except my brother and I to work on my car.
Therefore im looking for THE BEST TYPE OF OIL for a 07 328xi sedan.
Old 07-04-2013, 06:08 PM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
The oil needs to meet the BMW LL-01 specification. This narrows it down a lot. A couple of oils that meet the specification are:
BMW's own fully synthetic 5W-30 oil
Mobil 1 fully synthetic 0W-40 European Formula (not to be confused with other Mobil 1).
There are also some European market oils, such as Elf, Total, and Motul that meet the specification. These are not widely available in North America.
Alpinweiß
E46, E83, E90 (all with three pedals)
F25 (missing third pedal)
BMW CCA member
Old 07-04-2013, 06:37 PM
floydarogers's Avatar
Pedant and Curmudgeon
A couple other are:
Pennzoil Platinum European Formula Ultra SAE 5W-30
Valvoline SynPower SAE 5W-30
Those 4 are listed in your manual (maybe) and on the BMW USA website.
There are quite a few others that meet LL-01.
Old 07-05-2013, 06:04 AM
ProfessorCook's Avatar
ProfessorCook ProfessorCook is offline
Not a real doctor.
Mein Auto: 2009 328i Coupe
Re: Dont mean to be a pain
I'd change your oil and get the proper stuff in there ASAP.
'09 328i Coupe: MT, Monaco Blue, Black Dakota, Dark Burl, ZPP, ZSP, ZCW, CA, Logic7, HD Radio, IPod
Ordered: 14Jan09; Delivered: 24Feb09 from Stratham, NH BMW
Old 07-05-2013, 06:15 AM
3two8iguy's Avatar
3two8iguy 3two8iguy is offline
Mein Auto: 2011 E90 328i sedan
Ahhhh yes,The Midas touch,not so Golden was it?
Life is a Journey,Enjoy your ride.
Old 07-05-2013, 07:39 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
There's really only one option:
SEARCH
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 07-05-2013, 09:39 AM
BMW318i_E36 BMW318i_E36 is offline
Mein Auto: 2011 BMW 328i, 11 X5 35d
Can you check to see what oil they put in your car in the first place? I wouldn't be going to Midas for anything for my car IMO but check to see. You never know, if they might have put the right stuff in there but if your still worried, like I would be, get the oil changed with oil you know for this car.
Old 07-05-2013, 11:12 AM
Lufthansa Lufthansa is offline
Mein Auto: 2010 E92; '07Lexus GS350
I use Mobil1 in all my cars, and comply with the manufacturers weight recommendations in each. FWIW, I've never had an engine problem related to oils used, and I've owned and maintained cars since the '60's. I also average well over 100k miles on most, although I've gotten rid of some because they were problematic in other areas.
Old 07-05-2013, 01:46 PM
ptrcd003 ptrcd003 is offline
Mein Auto: 328i LCI
First of all, you can't tell oil quality by COLOUR. Second, the best oil to use is BMW oil. (also the cheapest) Where are you located?
Old 07-05-2013, 01:52 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
I'm guessing he meant that the drain oil was black, as opposed to brown-tinted clear as you might expect after 1,000 miles (?) driving.
OP: BMW OEM Synthetic 5W-30 always worked for me.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 07-05-2013, 01:54 PM
dlwjdwns1992 dlwjdwns1992 is offline
bmw4life
Mein Auto: E92 328i Coupe
i think...
I like the Royal Purple oil. The Nascar uses that oil (That's what i heard i think
They stands a while and goes for long. I am not here to advertise it, but still i'd prefer to put Royal Purple on my car.
Old 07-05-2013, 02:16 PM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
In case it helps...
http://www.bmwusa.com/Standard/Conte...ngineOils.aspx
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
Old 07-05-2013, 02:48 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
SEARCH
and you will be found
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 07-05-2013, 04:20 PM
im in burlington in ontario.
Old 07-05-2013, 04:24 PM
Ok i drained the oil and yes it was black instead of brown, i noticed my car was running wierd. so i took it out right away. my car is sittin in my garage atm with no oil until i find the best quality oil as in THE BEST that i can put in it.
i got the free oil change from the dealer i got it from. that midas should be burned to the ground, beleive me i thought about it
Old 07-05-2013, 07:12 PM
Originally Posted by RideForeign View Post
Ok i drained the oil and yes it was black instead of brown...
The color of the oil has nothing to do with it's condition. Only a laboratory analysis can tell.
Old 07-05-2013, 10:38 PM
harooni harooni is offline
2008 335i coupe
Mein Auto: 335i
oil should look brownish honey colored, it should never look black. i dont see why one would need a lab to know black oil is no good. now could it be they p;ut good oil and something burned it in the engine. yeah thats possible. but my best guess would be they figured it was synthetic and didnt change it at all.
2008 335i coupe sports package 2008 ML350
Old 07-06-2013, 10:02 PM
sptt144's Avatar
sptt144 sptt144 is online now
Mein Auto: 2009 335i
There's an article or You Tube video out there that discusses oil properties related to coloring and IIRC, black oil is not always necessarily bad and new oil doesn't necessarily stay honey like in color very long. Lots of varying factors that only lab testing can answer. But, to the eye, can't go wrong changing it when it looks like it needs it.
Sent from my SCH-I405 using BimmerApp mobile app
