Old 07-04-2013, 08:46 PM
bmrlvr4lf bmrlvr4lf is offline
Mein Auto: 528, 328ic, 318is
Fly/Flex plate/starter problem
1997 528i Automatic - Engine Swap - When I went to start it after all was put together is started but had a grinding noise coming from the rear of the engine around the starter. I pulled the starter out and turned the engine by hand - no noise. Looks like the front of the starter is making contact with the flex plate (see picture) I had the starter tested and it tested fine. I also loosened the flex plate and retightened it. Any help or suggestions would be appreciated. Ben
Name:	BMW FLYWHEEL.JPG
Old 07-05-2013, 02:40 AM
mjalloul11's Avatar
mjalloul11 mjalloul11 is offline
BMW forever
Mein Auto: 1996 528i 1999 MB C240
Did you use the starter that came with the engine or the old one you had? BMW used 2 starters one with threads for the screws on the starter and one with a screw and bolt like the old models. Maybe the length of the head you used is smaller and it hit the flex plate ?
Old 07-05-2013, 03:28 AM
525isport's Avatar
525isport 525isport is offline
Mein Auto: 2003 e39 525i sport (uk)
does the starter carry a shim or spacer between it ?
2003 525i sport uk import .see pic ^
1997 300 Tdi Landrover Defender
Old 07-05-2013, 04:44 AM
Thanks for the replies... I am using the starter that I had with my old engine. The used engine did not have one on it. I know it is the correct starter, it does look like I could shim it about an 1/8 inch and it would not rub. If I do that would that adversely effect anything else? Thanks again!
Old 07-05-2013, 07:39 AM
Burning2nd's Avatar
Under the lift arms
you loosened and tighting the flex disk? you mean the torque convertor?
15486372<-----
Old 07-05-2013, 08:59 AM
The 3 bolts that hold the engine to the torque converter. Thanks
Old 08-31-2015, 04:14 PM
scottieup! scottieup! is offline
Send a message via ICQ to scottieup!
Mein Auto: 1997 BMW 318I
I know its old
I know this is an old thread but looking at this pic tells me the flexplate was in backwards, was it?thanks
Old 08-31-2015, 08:14 PM
Yes. It was backwards.
Old 09-01-2015, 03:09 PM
monkeyman_69 monkeyman_69 is offline
Mein Auto: E39 528i
Since this thread got some life, I have a question.
I'm in the middle of a tranny R&R on my 97 528i. I also took off the flex plate (fly wheel) to get to the rear main seal. I put paint marks on the large triangle that bolts to the torque converter, the flex plate, and the thick plate the 8 bolts go thru, BEFORE I took them off.
I noticed the teeth on the flex plate are beveled (rounded) on 1 side and square on the other. My first guess was the rounded side faced forward, helping the starter engage. But after looking at my paint marks, the rounded area faces away from the starter.
I know my paint is right, yet it doesn't make sense. Why round the back side of the teeth?
