Old 07-04-2013, 08:46 PM
e39-540 e39-540 is offline
Mein Auto: 1998 540i
lighting problems, please help
hello all, I have a 98 540i and I'm having some lighting issues hopefully you guys can help me, first as I was leaving work the other night i noticed that my headlights came on as soon as I started the car the switch was off and did nothing, no cluster lights, turn signals, parking lights, reverse lights, hazard lights or 3rd brake light, all fuses look to be good what could be my problem a few people mentioned the hazard light switch and/ or the lcm. any help is greatly appreciated
Old 07-05-2013, 02:32 AM
mjalloul11's Avatar
mjalloul11 mjalloul11 is offline
BMW forever
Mein Auto: 1996 528i 1999 MB C240
Usually any light issue is the work of the LCM. Was it once that it did it or always?
Old 07-05-2013, 07:12 AM
it just started doing this, had had no issues up untill now
Old 07-05-2013, 08:30 AM
cn90 cn90 is offline
Search forum for BTS426L1 chips.
Then buy a pair on ebay for about $14.
Solder them in and you just save $1000.
Old 07-05-2013, 10:30 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
cn90,
From, what I've read, when the output transistor fails, the headlight stays on whether the ignition is on or not. Since all his external lights are affected, it's unlikely that all the transistors have failed at the same time.
e39-540,
When the headlights come on, turn on the passenger visor light. If this has an effect, likely the ignition switch is likely bad.
Otherwise, this may require DIS/MoDIC analysis.
