Old 07-05-2013, 09:22 AM
ashton540's Avatar
ashton540 ashton540 is offline
Mein Auto: 2007 328i
328i stalls..
Hey all. My 2007 328i has had a problem lately stalling lately when I hit the clutch at low speeds with the ac on at a higher speed. It doesn't do it every time and only does it with the ac on. Most of the time it saves itself but the car shutters and the engine will drop well below idle speed (200-300rpm) then bounces back. Thanks in advance for the help.
Blue 2007 BMW 328i
Green 1997 BMW 540i (Sold)
Black 1993 BMW 325i (Sold)
Gold 1993 BMW 525i (Sold)
PSALM 86:12
Old 07-05-2013, 09:47 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Do some research on the DISA actuator for the N52 engine. I take it you have no engine light as of yet?
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 07-05-2013, 10:32 AM
ashton540's Avatar
Actually, I forgot to mention in the original post that the service engine light came on and then went off yesterday.. The car has been doing this for a couple months now.. but got bad the last few days or so..
Blue 2007 BMW 328i
PSALM 86:12
Old 07-05-2013, 10:37 AM
ashton540's Avatar
I was also thinking this could be a vacuum leak as well. Im gonna go get the codes read today. I actually had forgotten that the service light came on yesterday for a bit.
Blue 2007 BMW 328i
PSALM 86:12
Old 07-05-2013, 04:42 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
>Cough<
Blasted your VANOS solenoids clean lately?
Old 07-05-2013, 10:32 PM
ashton540's Avatar
Service engine light went off. No codes
Blue 2007 BMW 328i
PSALM 86:12
Old 07-06-2013, 12:55 AM
That would be a first. What did you read 'em with?
Old 07-06-2013, 08:11 AM
ashton540's Avatar
Just ran by auto zone.. Would there still be codes if the cel went off?
Blue 2007 BMW 328i
PSALM 86:12
Old 07-06-2013, 08:18 AM
thekurgan's Avatar
Bad Lieutenant
They should be there until cleared.
Ilse
Bruna
BMWCCA #453648
Old 07-06-2013, 10:49 AM
Here we go again....Auto Zone has a generic reader that can't give you hidden, shadow; BMW proprietary codes.
THIS
or
THIS
Any decent BMW Indy'll have one....heck, I have one....so can you. Now about those VANOS solenoids....??
Old 07-08-2013, 03:04 PM
ashton540's Avatar
Is there a certain procedure to this at all? Or can I just get a can of breaks dust cleaner and go to town? What do you mean by blasting? Sorry to be ignorant..
Blue 2007 BMW 328i
PSALM 86:12
Old 07-08-2013, 03:11 PM
thekurgan's Avatar
Bad Lieutenant
I wouldn't use brake cleaner on anything under the hood. I would take this to an independent shop to be examined.
Ilse
Bruna
BMWCCA #453648
Old 07-08-2013, 05:51 PM
aleks001 aleks001 is offline
Aleks
Mein Auto: 2006 BMW 325i
I did mine with some MAF sensor cleaner, worked a treat. Just make sure you have nozzle on it so you can put it in the little wholes on the vanos solenoids. BMW also recommend using presurised air, but I don't have a compressor so I used the MAF cleaner and then blew in it a bit lol Also when you are done cleaning them, swap them around to see if you get a different problem or new codes.
I don't know if this is your issue though, but it is an easy thing to do and start with.
Old 07-08-2013, 06:15 PM
[CLICK HERE] -- and you can Google!
Old 07-08-2013, 07:06 PM
thekurgan's Avatar
Bad Lieutenant
OP I wish you luck, you don't appear to have symptoms related to this disassembly; but hell, if you are comfortable taking all that stuff apart, it's worth a shot. Until you know what code was/is stored, you're just wasting time, money and increase the chances of breaking something like those cheap plastic connectors on the solenoids. Let us know what your solution is, Kirk out.
Ilse
Bruna
BMWCCA #453648
Old 07-10-2013, 12:51 PM
ashton540's Avatar
I definitely know what the VANOS and the solenoids are.. And I also thought it to be a bit far fetched that it would be causing my issues. But, I never rule anything out. I've just never heard of walnut blasting them.. I'm thinking more of a vacuum leak or something to that degree. Car does not do it when the ac is off or at a low level. And if I blip the throttle right as I hit the clutch it doesn't do it. It only does it if its riding on a gear, in which case the fuel is cut off. For instance, if I'm rolling down a hill in 2nd or 3rd gear.. The car will almost stall and catch its self.. Kinda like its gasping for a breath. Only sometimes it stalls. I will get codes read this Saturday if I can.. Only problem is I live 40 min from the nearest BMW location.. So it's difficult to get the time during business hours for them. I appreciate the help and any opinions. BTW, aside from this issue car seems to run very smoothly as usual.
Blue 2007 BMW 328i
PSALM 86:12
