The X5 SAV Forum
Old 07-06-2013, 05:17 AM
sshaun2012 sshaun2012 is offline
Mein Auto: X5 e53 3.0i
Help Please Trans Failsafe Mode
Dear Fellow Bimmers. Desperately need help. I have two two major issues i need help with my e53 3.0i
1. Recently had my transmission overhauled due to failure. Changed all clutches, solenoids, filter, replaced fluids and reconditioned torque converter. Trans failsafe mode error comes out while cruising at 80 to 90 mph. However, it is still able to drive normally and change gears up and down. Also occasionally does not change from 1st to 2nd gear until revs hit bout 4000 rpm while light on throtle. Error that is indicated is converter lock up excessives slip. Have so far changed converter lock solenoid, battery as well as alternator after reading numerous forums. Desperately need help as i am running out of possible solutions.
2. Another issue is error code P0161 which is sensor heater faulty bank 2 after cat. Have replaced the o2 sensor but problem persists. Also switched the wiring with bank 1 but error code still there.
Please help.
Thank you.
Old 07-14-2013, 03:46 AM
No one can help???
Old 07-14-2013, 07:39 AM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
Given you replaced the sensors then I would suspect a problem in the wiring to that sensor.
Old 07-14-2013, 08:02 AM
Thank you, Zulu. Midst of checking the wiring to the o2 sensor.
Any ideas on my trans failsafe issue? Running out of options/ideas
Old 07-14-2013, 08:29 AM
Zulu95's Avatar
Not sure if it applies to you in this case but some of these "Failsafes" have been cured by replacing the internal wiring harness in the tranny.
GL.
Further thought:
Try posting over on xoutpost listing everything you have done. There are a couple (at least) of techs posting there.
Old 07-14-2013, 09:22 AM
Thanks, Zulu. Will do that.
